single/double sided...
[Closed] single/double sided pedals
i.e. spd one side/cage the other...I never know what to call them!
Does anyone use them off road and ride tricky sectopns unclipped?
Thinking of trying this with some A530s I have coming - should be easy to put studs in the cage side, and they would have more clearance in narrow stuff than flatties.
Posted : 08/05/2011 7:04 pm
Thought the general consensus on those was that they were rubbish. Would be kinda hard to change from one side to the other, and how grippy is a shoe with a cleat in it?
Posted : 08/05/2011 7:07 pm
Cleat is recessed.
Re. turning it over - I manage that fine on my other pair (M524?)
Posted : 08/05/2011 7:10 pm
My first cleated pedals were the M324s. I reckoned it would be great to be able to unclip on tricky sections. In practice, I found them to be just too much hassle. As RealMan says, it's amazing how little grip a cleated shoe has on a metal cage pedal - even though, as you say, the cleat is recessed.
Posted : 08/05/2011 7:19 pm
I feel you druid but adding pegs/studs may give clearance for the cleat, will def give way more grip, and the shoes in question have a lot of rubber around the cleats. I'm going for it ๐Ÿ˜ก
Posted : 08/05/2011 7:25 pm
Are you going to glue the studs on with papier mache this time as well?
๐Ÿ˜€
Posted : 08/05/2011 7:39 pm
Won't that work โ“
๐Ÿ˜ก
Posted : 08/05/2011 7:40 pm
 mboy
They're better than a disc brake mount fashioned out of an old spoon...
But only marginally mind! ๐Ÿ˜‰
Posted : 08/05/2011 7:41 pm
