Single v double on ...
[Closed] Single v double on a gravel/road bike.
I have ordered a PX Tempest, now; I was wanting to get it as a double but that is a bit spendy for one chainring and some shifter internals. So, I have a hydo 105 double groupset on my road bike, my question is this; I want the Tempest for the landy tracks here but I also want to ride it on the road a bit with different tyres, Will 1x leave me cursing or will I just grow smarter with gear shifts? Road rides usually anything between 30-60 miles depending on motivation/cake intake. To be honest I would like it to be a bike to replace both road and my hardtail (which really only goes bivvying/camping.) Cheers.
Posted : 31/03/2021 9:50 am
I have a 2x on my gravel after I convinced myself that 1x was not the way to go. I don't regret it all - I love 1x on my MTBs, but for anything with more constant pedalling I'd really not want ratios any further apart than on my 2x with an 11-32, but need the range that a 2x gets me on that cassette because puny legs and lard intake.
Posted : 31/03/2021 9:55 am
I have a tempest (amazing bike), which started as sram 1x and is now 2x11 grx. 1x was fine to be honest, but I do prefer the new setup.
Posted : 31/03/2021 10:00 am
I currently ride with a 3x9 setup 11-34 30,39,50. I'm experimenting with the idea of 1x simply by avoiding the big ring and the granny ring.
What I have noticed is that more often than not, I'm riding in a gear of between 1:1.5 and 1:2. That puts me nicely in the middle of the cassette with the middle ring.
If I compare that it a 2x system 11-34 with 31,48 chainrings, it looks like most of my riding would be at the cross over point between the two chainrings.
Maybe it's just me, but it seems like I'd be better off with 1x rather than every second on third shift needing a front shift to go with it.
Posted : 31/03/2021 10:03 am
Depends on your riding style. If you are head down arse up kind of rider and riding in groups you will want a 2x. If you ride solo and are happy to go at your own pace then 1x is fine.
Posted : 31/03/2021 10:04 am
1x on the mountain bike, 2x (subcompact) on the gravel bike. I find gravel rides tend to be faster than MTB rides, and 2x gets me the right/gear cadence, with smaller gaps between them. On the MTB I ride slower and I'm happy for cadence and gearing to govern speed, not the other way around.
Posted : 31/03/2021 10:26 am
Traileagger is correct
Posted : 31/03/2021 10:31 am
2x for me but mainly because I want the range without massive gaps. The gravel bike does everything from steep climbs up mountain tracks to hammering along A roads. So a GRX 31x48 chainset paired to an 11-40 XT cassette gives me a 563% range with manageable gaps.
Posted : 31/03/2021 10:33 am
Also consider if you are going to be carrying luggage and the distances you'll be covering. A wider range can make uphill load lugging easier and still give you a decent speed for any longer tarmac segments.
I'm currently 50/34, 11-40 but I'm likely to reduce the front to 48/32 or 46/30 when the rings wear. Some will say that it's difficult to spin out on the smaller rings anyway but we don't all have a comfortable cadence in excess of 80 rpm.
Posted : 31/03/2021 10:42 am
Depends how sensitive you are to cadence changes. I’ve ridden mtbs since the late 80’s with 3x5 and was used to big cassette jumps. When I had a good road bike I used to find I changed 2-3 gears at a time as the difference between one was barely noticeable. My 1x gravel bike has a wider range than my 2x winter road bike with an 11-28 cassette and one gear change actually makes a difference. May well help that being Force 1 it has the same spacing as my mtbs (even the 12spd minus the 50).
Have done rides with others on road bikes, but only 3-4 riders on chill rides. Could be different in a chain gang but unlikely you’re considering a gravel as an only bike if you’re into that kind of thing.
Posted : 31/03/2021 10:44 am
Kind of agree since group rides on road was where 1x felt least effective to me, but I generally don't ride head down or in bunches and I still prefer 2x.
The main advantage of 1x is chain retention (and perhaps some clearance gains) and that's something I don't need on a gravel bike. Yes a churned byway can be rough and I'm not always a pootler but still, I just don't have a problem with dropped chains. A clutch 2x mech is plenty. Since I don't need the retention levels of 1x I go for more adaptable gear ranges/choices and the cheaper mechs and cassettes of 2x, works for the longer distances and subsequent wear rates that the gravel bike sees (though I do hear good reports on 12s cassette life).
Posted : 31/03/2021 10:45 am
2x for versatility definitely.
I've been 1x for most of the winter, 38 x 11-40. It has been mostly great, but for longer more explorative gravel rides I miss the range of the 2x setup.
I'm a bit phobic of massive cassettes as well, I guess you could go 1x with a massive cassette but in my experience shifting gets worse/more sensitive to setup with bigger cassettes.
That being said, the worst thing about 2x is Shimano's new front mechs, they seem awfully fickle! If you can go 2x without using GRX cranks and buy an older style shimano front mech then that would be the best of both worlds.
I think you're right to be honest, although I do use most of the range of my 2x setup, I do seem to use the front shifter an awful lot (although I dislike running the chain crossed over, I really don't like being in the big ring and biggest two or three sprockets).
I think sub-compact 46/30 is the way to go.
I also agree with Roverpig/Scotroutes, my ideal setup would maybe be 36/40 and an 11-36 or 11-38 cassette, but since they're thin on the ground I might just go 2x for summer and keep my 11-40 cassette on.
Posted : 31/03/2021 11:09 am
1x on the mountain bike, 2x (subcompact) on the gravel bike. I find gravel rides tend to be faster than MTB rides, and 2x gets me the right/gear cadence, with smaller gaps between them. On the MTB I ride slower and I’m happy for cadence and gearing to govern speed, not the other way around.
+1
It's not so much the range as the cadence that annoys me. Standing up to mash my way up a hill feels fine, tucking to wizz down a lane at 30mph rather than 32 is also fine. Getting stuck between two gears on a fast smooth section is just infuriating.
Whereas on the MTB (for reasonably technical riding anyway) 1x12 annoys me for the opposite reason, there's rarely time between features to find the right gear. On the singlspeed you kinda get used to when the gear is useable (maybe even 90% of the time), 12s you come out of a corner, pedal, nothing, shift 3 gears, pedal, next corners on your already. I like the evenly spaced low gears but I dont think I'd miss the <16t sprockets all that much. Which conveniently makes the range 314%, roughly the same as an 11-34 cassette. I'm tempted to pick up a 2nd rear wheel, 11-36 cassette and 24t chainring (not sure that exists though) and try it out.
Posted : 31/03/2021 11:12 am
Thanks everybody,definately going with the 2x11 then and will have to suffer the the pain of swapping them over before I ride my shiny new toy.
I don't ride gears but every time I think about it I find myself looking at cassettes that are
11-12-13-14-15-16-17-19-21-23-25 and with a single ring on the front that would be perfect for me. I have no need for wide spaced dinner plate sized cassettes.
Posted : 31/03/2021 11:20 am
2x on mine (34/48) which was quite a specific set-up for a purpose. However the bike has now morphed into a do-it-all winter road bike, gravel/CX bike and actually it's perfect.
I like being able to quickly get to a lower gear simply by dropping from big ring to small without the need to shift up 6+ cogs at the back - it's handy for going from road to gravel. Since the vast majority of my riding is mixed use of normal roads and trails, having the reasonable range of higher gears for road use is good.
Posted : 31/03/2021 11:26 am
Late to the party but I like 1x on my cross/road/gravel/whatever bike (10-42 cassette). It has the range I need almost all of the time.
It’s very much a personal choice though. I found closer ratio cassettes annoying and was constantly changing multiple gears. When I could get a sensible gear range with my preference for gear steps, and that happened to be 1x, I went for it (The fact I like the looks is a happy benefit). If I was riding in close groups on road all the time I might change my tune.
Setup- I do have two chainrings (38 and 42) which might get swapped depending on what I’ve got planned for the next few months (mostly road vs lots of off road) but that’s less faff than swapping tyres at the same time and it rarely bother me to have the ‘wrong’ one. I should probably stick a 40 on there and forget about it when they wear out...
Posted : 31/03/2021 11:47 am
 pdw
1x on my gravel bike, but I wouldn't want it on my road bike. I want much lower gears on my gravel bike 40/11-46 vs 50-34/11-28 and I find my 11-46 Sunrace cassette has some annoying gaps at normal road speeds.
Plus, 1x is always annoyingly noisy in lower gears.
If the Tempest is 1x SRAM, you can probably pick up the bits to make it 2x for very little as loads of people go the other way. I've got various bits from my CX bike, although annoyingly I lost a small bit of the shifter internals.
Posted : 31/03/2021 11:56 am
Most of my rides during this last lockdown have been on my (not being used to) commute bike; a Croix de Fer with 1x (40T) and a 11-32 cassette, 32mm road tyres mudguards rack etc (ie a heavy beast). For road riding solo and the sort of distance the OP is talking about the gearing has been fine. Might spin out once or twice on fast descents (just tuck in) and use the 32 a couple of times as well on the short sharp hills around here (Hampshire & South Downs area). Riding solo I haven't had any issues with big jumps between ratios, now that we can ride in groups again and the weather is improving I will probably revert to my road bike but mostly because its a couple of kg lighter than the CdF.
For off road use this 40-32 wouldn't be low enough and I would want to at least swap the cassette for something with a bigger range. Is that an option for you? When you want to go off road swap the cassette as well.
For mixed road and gravel riding a 2x does still seem best to me. To the extent that I have a new bike on order: Enigma Escape with GRX 2x. Looked at the Campag Ekta 13spd as a possible option but expensive and would have much preferred if they had used the extra cogs to fill in the gaps rather than go for a 9 & 10.
Posted : 31/03/2021 12:39 pm
If the Tempest is 1x SRAM, you can probably pick up the bits to make it 2x for very little as loads of people go the other way. I’ve got various bits from my CX bike, although annoyingly I lost a small bit of the shifter internals.
Now thats interesting.
Posted : 31/03/2021 12:46 pm
 pdw
I'll check what I've actually got. I've definitely got a spider + chain rings. I can't now remember what bit it was that I lost from the shifter internals. It might have been a circlip, in which case I might now have a replacement.
Posted : 31/03/2021 1:06 pm
I've got SRAM Apex 1 on my Sonder Camino - 40T chainring and a 11-42 cassette.  It's a good allrounder but I find that I'm under-geared on fast road sections and over-geared on steep lumpy bridleways (a dodgy knee doesn't help). It's a compromise. My next bike will be a GRX 2x
Posted : 31/03/2021 1:27 pm
kerley
I don’t ride gears but every time I think about it I find myself looking at cassettes that are
My application is similar to what the OP describes. Road rides up to c.60 miles and some local off road. No luggage. This bike lives in a pretty flat part of the country though. It's currently singlespeed 42:18 in which just about everything it does is just about doable but the sharper tarmac climbs even in Northants have to be attacked. That said, I just don't see it as a "sit and spin" kind of bike, so I'm happy mashing.
Also, I'm interested in the option of a dropper and using the LH shifter for that seems a far neater solution than any other. And going 1x would avoid a crankset purchase.
So I'm thinking about fitting gears but it's mostly to add much higher gears for longer road rides and to give me the option of riding with a group, but not a fast one. I reckon I could get away with 1x without a huge cassette. So probably in the same camp as Kerley albeit maybe a slightly wider range cassette. But that's because of where I am. If we had hills I'd be thinking differently.
All that said, the current market for bike parts has put all this firmly on the back burner for me.
Posted : 31/03/2021 2:05 pm
I enjoy the off road bits more on my gravel bike so geared it for that but I find 40x11-51 is plenty fast enough for me on the tarmac bits between trails
Posted : 31/03/2021 2:11 pm
1x10 for me (38x11-36) but I'd agree if you want a bit more versatility and/or to use it as more of a road bike/tourer 2x makes sense, especially a sub-compact. My Gravel bike is more of a Local on/off-road Hack machine.
I chose 1x for minimal maintenance, having fewer components to set up (queue someone whinging about the demise of front mech setup skillz), mud clearance and just general convenience.
My Summer Road bike is 2x and while I've mulled going 1x on that too, I don't think I will as the available options don't quite match up to what I want that bike to do...
Winter/Commuter Roadie is 1x9 (42x11:34) with friction shifting, purely for extra cheapness and simplicity.
Posted : 31/03/2021 2:12 pm
i like 1x.. im used to it.. and means parts are more swappable between my mtbs...
44 x 10-42 covers me, i dont feel there's a hill i can't tackle..
i generally dont feel massively happy about 30+mph on the road either but its still a sensible cadence downhill at those speeds
if i dont like the ratio ill gladly take the next nearest.. or alternate between, im not riding in groups at continuous pace
Posted : 31/03/2021 2:29 pm
Newer Shimano mechs require more luck than skill anyway, it's as if they wanted to prove the 1x-ers point for them! I can't even get the 105 mech on my road bike working properly across the range...
Posted : 31/03/2021 3:42 pm
My Tempest started as Ultegra 34/50 and 11-34, which was overgeared for off road and ageing legs.
It's now GRX 30/46 with an 11-40 on the back. I mostly leave it on the inner ring when off road and lugging bags. Outer ring for chattery descents and road riding.
Perfect for me.
Posted : 31/03/2021 3:48 pm
Newer Shimano mechs require more luck than skill anyway, it’s as if they wanted to prove the 1x-ers point for them! I can’t even get the 105 mech on my road bike working properly across the range…
Don't the latest ones just have a little indicator that you line up and it's done?
Posted : 31/03/2021 4:11 pm
Well 30odd years ago when 6 speed cassette was fairly normal I rode 52/42 (didn't we all?) with 11-21 or 11-24. There is no way I could get up anything remotely like a climb on those sort of gears now, even on the road. Definitely not on gravel.
For those using 2x and 11-40, what rear mech suits, GRX? At my age and lack of strength I could quite fancy having 30x40 available.
Posted : 31/03/2021 4:45 pm
I had to follow the instructions carefully first time I came across one. I can't say I've had any subsequent problems, and that includes the 105 on my own #gradventourer.
Posted : 31/03/2021 4:50 pm
I'm using the Ultegra RX (for the clutch). A standard Ultegra worked too but there seemed to be a bit too much chain slap.
Posted : 31/03/2021 4:52 pm
Yes Ultegra RX for me too.
I swapped the 105 front mech and chainset for a GRX one (to lower the gearing a bit) so had to deal with the modern generation front mech. It was the first one where I've actually had to read the instructions (and watch a few videos in advance). Maybe I did just get lucky, but I found the setup quite straightforward in the end. Having the little sticker to get the height right and the adjuster for the cable tension with a mark to show you when it was right seemed quite neat. The mark is just a guide though. Nothing wrong with adjusting it to get it all running sweetly as far as I could see.
Posted : 31/03/2021 5:42 pm
Did KAW on 1x and found myself lacking gears compared to friend on 2x. Local rides and it’s no different, so bags and long days and I’ll be 2x
Posted : 31/03/2021 5:50 pm
I keep looking at getting a bike through the bike to work scheme. Not sure I need or want a full on gravel bike, but something with larger tyres than my road bike to cope with the awful roads round here, as well as heading down some bridleways when the mood takes me.
A lot of 'gravel' bikes seem to be set-up 1x, but I hate feeling like I'm in the wrong gear which I think I would feel if I went 1x.
I reckon if I do get one, it'll be 2x. I keep looking at the Spesh Diverge Elite E5, but with stock the way it is I'll probably put this idea on the backburner until next year.
Posted : 31/03/2021 5:52 pm
I have a Diverge with 1x and I’ve just ordered a 38 chainring for longer days in the saddle, but it would be seriously over-geared for multi-day/laden adventures. I’ll probably wait until next year given the scarcity of parts to upgrade to 2x and kid myself I’m 10 years younger.
Posted : 31/03/2021 6:01 pm
I use my 'gravel' bike probably 80% road, 20% gravel (or mud)
I had a 1x Pinnacle Arkose which was a great bike but the gaps between the cogs was just getting annoying for road riding.
Changed to a Checkpoint with 2 x 46/30 and 11/34 at the back and it's best of both worlds imo.
Gets up anything with the low gear but is nice to ride on the road without big cadence jumps.
Posted : 31/03/2021 6:16 pm
Despite owning one I couldn't tell what a gravel bike actually is but there are plenty at the racier end of the spectrum that do just seem to be road bikes with clearance for larger tyres.
Posted : 31/03/2021 6:18 pm
Trailwagger +1
It's all up to you and what you're doing really,  my preference is 1x and I have the option of 2x if I ever want it, but dont. So 1x it is.
Cant say as I'd want 1x on a road bike mind you.
Posted : 31/03/2021 6:27 pm
If the the bike is a do it all road, gravel, touring etc a double is good mines has a 48:32 on front with 32 11 at back I think. If it's a more focussed off-road bike a single may be better, but then front mechs never cause me an issue tbh so why not have one?
Posted : 31/03/2021 6:54 pm
Dunno if it's possible with cable set-ups (and I assume not, as I've not seen it), but a SRAM 10-50 Eagle cassette (using Force 1 AXS shifter and XX1 AXS mech) works great on my 1x gravel bike. Plenty of range, and I can't say I find the gaps annoying - mebbe it's just what I'm used to...
Unless I ride an actual road bike again, I can't see me ever using a front mech in my future - even on a 7 week tour of France I'm planning next year.
Posted : 31/03/2021 7:10 pm
My cross bike is 1x with a 38T NW. For road I run 1x(11-23) and for off road I run 1x(12-32). you will need two sets of wheels but who wants to change tyres? On rolling medium-paced club rides road I often run 1x1. Fixed. But otherwise a double.
I have a Bombtrack Hook EXT Carbon running 650b (knobbly 50mm winter, faster 47mm summer). It was set up 48\32 11-34 originally, the Praxis Works Zayante Carbon cranks decided to fall apart on me so I then went 1x40 11-46. I wasn't sure initially but like the MTB I preferred the simplicity and didn't overly miss the extra gearing shortly after. It's done a few thousand miles on the setup and I'm totally happy with it. It's done plenty of big offroad rides too, did a mostly offroad 100mile Chilts gravel ride end of last summer which intentionally was supposed to be a hard day of steep climbs and it was fine gearing wise (luckily legs were okay too!). With my setup there's enough gearing for steepest climbs i can find and about 27-30mph limit before I may as well stop pedalling and just get aero if on a proper descent or tail wind on a super mild downward false flat.
Agree with comments above, providing the road side of riding isn't a smashfest in a group then it's perfectly doable. If you want the extremes on gearing on and offroad then a double would be better. Third middle option otherwise is run a chainring suitable for the roadrides and easier\faster offroad and you can always swap to a smaller chainring for big days out or slower winter riding.
Posted : 31/03/2021 7:19 pm
Do you like complexity? If so go 1x. You have swapped the more reliable, easy to set up moving part on a bike, the front mech, for something that is over complex, over price and vulnerable, a long rear mech.
More reliable as only you can decide is can you live with the gaps in gears?
Posted : 31/03/2021 7:43 pm
Dunno if it’s possible with cable set-ups (and I assume not, as I’ve not seen it)
The Path Less Peddaled guy on YouTube has done a series of videos on various (what he calls) budget mullet setups i.e. road (cable) shifters with MTB cassettes. Some work better than others but I think the simplest one just involved replacing one part on an Eagle mech to make it work with road shifters.
Posted : 31/03/2021 8:33 pm
Thanks for the mech advice.
Posted : 31/03/2021 8:36 pm
I saw that. Got me thinking, as SRAM and Shimano seem interchangable at 12 speed, could you run a shimano 10-45 cassette and XT mech with a converted SRAM shifter.
Posted : 31/03/2021 8:38 pm
Not sure if the below article might help...
https://blog.3t.bike/2020/01/12405/gravel-bike-tech-gears-for-tough-climbs-part-1/
Posted : 31/03/2021 11:29 pm
I've 1x GRX on my cross bike (40t chainring with 11-42t cassette) and like it but could see it being not the best for fast road rides or steep hilly off road, so just like all 1x gear systems really. I prefer the simplicity myself but can see that others would prefer more gears.
Posted : 31/03/2021 11:58 pm
On my GT grade I have the bog-standard 40 11-42 I find this is fine for hilly road rides and undulating gravel but when you get to long technical climbs i could do with more gears.
My other gravel bike runs mtb gears 38t/28t at the front and 11-42 at the back. It was built specifically for climbing huge gravel climbs in the Pyrenees where normally gravel gearing wouldn't cut it for me but also wanted to shove some road wheels in and ride up the cols as well.
I got chatting to a guy whilst waiting for a herd of cattle to pass he was running a 48 tooth singe ring at the front and 10-50 MTB cassette at the back on a tt bike it was SRAM and it wasn't AXS so it can be done.
Posted : 01/04/2021 12:02 am
OK if you say so...
I'm using an old (as in over a decade) MTB mech and have yet to find this technology anymore over-complex, overpriced or vulnerable than it was flapping about on an MTB...
As for the bigger steps? Yeah That's absolutely the case, but it's a chosen compromise, some bigger cadence jumps is the trade-off for wider range (on 1x), it still suits some of us...
I guess it comes down to whether you see "gravel bikes" as more "off-road capable road bikes" or more like a "more efficient MTB alternative"...
Nobody's saying there's anything wrong with fitting 2x to a Gravel bike, I don't know why some people feel the need to attack the choice to use 1x on a drop-bared bike. Is there some sort of religious derailleur orthodoxy?
Posted : 01/04/2021 1:08 am
I've been running 2x9 I cobbled together on a monstercross just before Covid hit; 40-28 XT chainset & mechs, Alivio 11-36 cassette, Sora levers. After 4500km of mixed local rides, bikepacking and 100km day rides, I like it enough to throw money at it - and have assembled the parts for a 1x11 refurb. With a 40t chainring and an 11-51 Deore cassette I'd get exactly the same gear range, but I'm putting on a 38t because I anticipate doing more loaded touring on the new build.
[img] https://64.media.tumblr.com/3624a0d303bd72bda2e3fb4b7cd329ef/805e19c3d4fb5cd0-aa/s1280x1920/e572772d0379bd9b199db48d71354401e283211b.pnj
[/img]
Curious to see how the relative merits work out.
Posted : 01/04/2021 5:32 am
@montgomery what rear mech and shifters are you planning to use ?
Posted : 01/04/2021 7:46 am
With a 40t chainring and an 11-51 Deore cassette I’d get exactly the same gear range, but I’m putting on a 38t because I anticipate doing more loaded touring on the new build.
I've had a 26-38 double on a gravel bike for while, std 10s rear block, and one thing I found suprising is that 38-11 is not too low for most of the road miles I do on this bike - I just tuck or freewheel earlier on faster hills or spin a bit faster at times. Nothing that bothers me anyway. Certainly had me agreeing that 1x can give the gear range needed for vast majority of riding. The lowest gears I have (26 x 32 or 36) rarely get used unless the bike is loaded up.
Posted : 01/04/2021 7:57 am
The newer front mechs aren't harder to set up once you realise that the screws don't work the same way as the older ones and you read the instructions, however they do need particularly free running cables for the trim to work nicely which can be an issue. I have to widen the frame hole in my Cube to remove a link from the cable run.
Posted : 01/04/2021 9:55 am
This is the conclusion I was trying to avoid arriving at! Oh well, that's what wet Easter weekends are for I guess, replacing internally routed gear cables on 2 bikes...
Posted : 01/04/2021 10:50 am
 pdw
@duckman this is what I've got:
I think the bit that I lost was a e-clip that goes on the pin in the middle of the picture, in which case I do have replacement clip that fits well enough.
Please don't ask me how it goes back together 🙂
It's SRAM Force 22, but pretty sure it's interchangeable with at least the other 11 speed stuff.
I've also got a spider with 50/34 chainrings.
Posted : 01/04/2021 1:18 pm
I ride with a group and use my Tempest as a road bike. Still got the 1X Sram and like the simplicity. For me, just better more road friendly tyres, was a more pressing upgrade, maybe 2X later but not urgent.
Posted : 02/04/2021 2:21 pm
@Stainypants
Initially considered these but ended up going for Microshift bar end shifters instead, leaving me more options for standalone brake levers. I might use the left hand shifter if I decide to go back to a 2x setup. Just going with a 12 speed Deore mech until I see how it works out.
Posted : 02/04/2021 2:31 pm
