Anyone know if it's possible to fit a 32T chainring on the outside (big ring position) of an XTR (current 2009) crank?
I want to use the crank for SS but my chain line will dictate the big ring position.
Posted : 22/05/2009 9:45 pm
Yes you can do it, but if you can adjust the chainline then put it on the inside.
Posted : 22/05/2009 10:04 pm
I want to use a Phil Wood KO hub and a WI freewheel, whihc gives about a 54ish chainline.
There isn't really any leeway with XTR is there?
I was/am looking at WI eno cranks and a Phil Wood BB but am wobbling!
Posted : 22/05/2009 10:25 pm
