Single ring for an ...
[Closed] Single ring for an M952 XTR crank
Does anyone make a ring that will bolt straight onto the M950/2 generation of XTR cranks? I use a spider from a similar generation of XT cranks at the moment and run a std 104mm ring but wondered if there was a sleeker alternative.
Posted : 26/03/2012 9:25 pm
boone do or at least did, and a company called jericho
Posted : 26/03/2012 9:26 pm
Crumbs. It takes some digging about on the net to find those. I suppose what I am looking for probably falls well under the umbrella of niche.
Posted : 26/03/2012 9:59 pm
middleburn do a xtr mount spider to put 104 bcd ring on an xtr crank, in all sorts of colours
Posted : 26/03/2012 10:00 pm
Homebrewed components but do a check on here as to recent delivery times... not good... But if your not in a hurry and the guy gets his s&£@ together they are good.
I have a Jericho Suffering and have had Forge rings in the past, both not available now... but I can show off 😛
Posted : 26/03/2012 11:04 pm
