Should I replace my...
[Closed] Should I replace my BB?
Bear with me ๐Ÿ™‚
My bike is in bits following my frame bearing traumas
Ive eventually removed all the buggers and its taken ages
In the meantime Ive stripped the whole thing back to bare bones removing the crankset etc etc
If I was going to replace the BB I cant think of a better time
Im a lazy arse and hate maintenance
On the other hand it seems fine - no play or crunching at all
And on the other hand a new Shimano BB wont break the bank and will be easy to screw in whilst the bike is in bits
And on the other other hand theres nothing wrong with the current one which will be a b4stard to remove and probably cause even more trauma and stress
opinions welcome ๐Ÿ™‚
Posted : 04/01/2010 11:31 pm
why will it be a b4stard to remove.they normaly come out a doddle.
Posted : 04/01/2010 11:34 pm
 Smee
My opinion is that you're a cack handed gibbon and that you should step away from the vehicle. ๐Ÿ˜€
Posted : 04/01/2010 11:42 pm
 dano
It really does only take 100 mins to change a bb... if the bearings are fine, then you should carry on using it and just pull the crank off and change it when needed...
Posted : 04/01/2010 11:45 pm
take it out, check it, clean & grease the shell threads
then put it back if it's OK
 dano
edit 10 mins
It's easier to swap a BB on a built bike. And it doesn't need changed. So, leave it alone.
Posted : 04/01/2010 11:51 pm
You've got, like, 4 hands??
Posted : 05/01/2010 10:16 am
You could pull it to bits and clean it out and get some fresh grease into it if you feeling a bit dardevil, if there isnt anything wrong with it then a little tlc will keep it spinning indefinately...
This is a guide on replacing the bearings but if you have got the good bearings out your not far off removing the lip seal and adding fresh grease.
http://www.mountainbikerides.co.uk/fettling/hollowtech2bb.htm
Posted : 05/01/2010 10:37 am
