Should I get a Mari...
[Closed] Should I get a Marin?
Just seen the Marin Bobcat on JE James Cycles for £359 when i apply their 10% discount code but is it a good deal?
Spec below what do we think?
Frame 6061 Aluminum, Double Butted Hydro-Edge II Top and Down Tubes, E4 Anti-Flex Seat and Chain Stays
Fork Suntour XCR-LO, 100mm Travel with Hydraulic Lockout
Headset FSA No.10, 1 1/8?
Rear Hub Formula, 32 Hole
Front Hub Formula, 32 Hole
Spokes 15 Gauge Black Stainless
Rims Alex XD-Comp
Tyres Continental X-King, 26? x 2.2"
Shift Levers Shimano Acera Rapid Fire Plus, 9 Speed
Front Derailleur Shimano Acera 9-Speed
Rear Derailleur Shimano Deore Shadow
Cassette SRAM PG-950, 9-Speed, 11-34
Chain SRAM PC951
Crankset TruVativ E400 3.0, 44/32/22T
Bottom Bracket TruVativ with Sealed Cartridge
Seatpost Comp Alloy Micro Adjust, 2014 Alloy, 15mm Offset, 400mm
Posted : 29/11/2013 12:06 pm
Looks a good buy to me that. Spec is all serviceable, reliable stuff. If the bike fits/suits you then go for it.
Posted : 29/11/2013 12:45 pm
Agreed, looks decent for the spec and every Marin I've ever used has been good and solid if not mind blowing.
Posted : 29/11/2013 9:38 pm
I've owned three Marins in the past five years. Solid, reliable bikes.
Posted : 29/11/2013 9:41 pm
Rocky Ridge was fairly mind blowing back in the mid 2000s..... 🙂
Posted : 29/11/2013 9:49 pm
I have a Marin from 1999 that's still my main bike, and (amongst other things) has survived 7 passportes...
Posted : 29/11/2013 9:53 pm
 mrmo
only thing i would caution, i don't know what the manufacturer backup would be like now that ATB sales no longer deal with them.
I doubt you would have to use it but it is something to be aware of.
Posted : 29/11/2013 9:54 pm
26" wheels ? Are you mad ?
Posted : 29/11/2013 10:08 pm
I wouldn't panic about warranty. At the risk of sound blasé it's a £300 bike. If anything breaks it'll either A)Cheap to replace quickly rather than fanny about with claiming & B) a good excuse to upgrade. In any case shouldn't the retailer be your first port of call?
Posted : 30/11/2013 1:35 pm
Defo wouldn't worry about warranty either as a lad on retrobike just stuffed his carbon Marin. It was third hand + out of warranty but the new Marin people still sent a brand new frame.
Posted : 30/11/2013 8:32 pm
I've had three Marins, and still have my first, a 1999 model which I've had from new.
Broke the other two, excellent warranty support, and all three great bikes, highly recommended.
Note though that just because J E James advertise something doesn't mean they actually have any. Has anyone ever managed to buy anything they have on their website? 99.9% of items are out of stock, unless you need shoes in either size 2 or 15.
Posted : 30/11/2013 9:41 pm
