Should a chain guid...
[Closed] Should a chain guide rub?
Having broken a rear mech due to a lost chain over bumpy ground I'm reluctantly fitting a chain guide.
I've opted for a OneUp Components BB mounted version. I have a Works Components oval ring, Race Face Evolve cranks, 11-42 cassette & 425mm chainstays.
I've fitted 1.5 spacers and the best it gives me is some rubbing at each extremity of chain line.
Is this normal? Am I missing something? Will it just bed in and shut up once worn?
I love a quiet bike.
Ta.
Posted : 17/05/2018 10:59 am
One bike is silent and one just tickles the guide on the lowest gear. Both run ovals.
Posted : 17/05/2018 11:01 am
A wee tickle is alright- it'll self clearance over time anyway- but if you're having rub at both ends I think maybe it's too far back? I have mine (a Shovel but it's basically the same thing) mounted basically directly above the BB so changing gears doesn't affect it much
Posted : 17/05/2018 11:27 am
Can’t say I’ve massively noticed my one up chain guide rubbing a lot - but perhaps it did a bit at the start and it’s now worn itself a little groove so it’s fine!
Posted : 17/05/2018 11:43 am
Depends on the bike, chainguide, drivetrain and fitting patience/bodgery.
Some you can set up silent, some will always rub.
Posted : 17/05/2018 3:05 pm
I think the file may be making an appearance, it's taunting me as I winch up steep bits.
Posted : 17/05/2018 3:13 pm
