for a mate later. Can you reuse the olive and barb like you can with avids if your carefull. Also do you need the special bleed screw bit or can you get by with a syringe and variouse tubes. Cheers tah.
Posted : 03/02/2010 11:33 am
New olive needed, though you can bodge a bleeding kit together without too much agro.
Posted : 03/02/2010 2:44 pm
And you definately cant get the old olive off by cutting away at the left over hose and open it back up enough with a very small socket to get it back over the cut end of the hose. Done this many times with avids when i have ran out of olives.
Posted : 03/02/2010 4:06 pm
