Looks like CRC aren't taking CycleScheme until H2 2023 so the Vitus Rapide FS CRS is off the menu.
I think I've narrowed it down to:
1) Marin Rift Zone 3 (2022) - Circa £2k but probably an uplift to pay for using CycleScheme. Well reviewed, but not mirospline as uses a Sunrace cassettte to get around using an HG hub.
2) Sonder Cortex NX Custom Build - RockShox Pike Ultimate - £2399
3) Bird Aether 9 (paint imperfections, cost uplift due to CycleScheme, circa £2700)
4) Ibis Ripley AF Fox Performance Doere (£2750 due to Cyclescheme premium)
To me it seems the Marin Rift is winning, I'd love to try and save weight but doesn't seem like any of the above are sub 14kg anyway?
Really appreciate any help as wanting to get ordered. Main uses will be light rails, heading out with the kids and the occasional 20 mile round commute (so don't want Enduro levels of travel).
Thanks
What spec is the Aether? I’d probably take that having had 2 Bird bikes before and being happy with them + customer support is ace.
Marin are pretty good these days too tbh - it’d be down to which has the best spec between that and the Ibis for me I think.
Not a fan of the look of the Cortex - although if you’re after something light / quick / efficient that might be the best option as the shortest travel / least burly.
Edit - had a detailed look at specs and whilst the NX is low rent on the Cortex it does have a brilliant fork. I still don’t like how it looks though.
The Marin is decently specced as is the Ibis really. Ibis has a similar fork - but it’s lighter than the Z2. Geometry on both is pretty similar. Wheels are own brand stuff on the Marin.
Bird will probably have better wheels whatever spec it is as they only tend to use dt Swiss factory wheels or Hope hub / dt swiss rims.
Just noticed the imperfect paint build is an aether 9c - had a fiddle with Shimano 11 speed and made it £2900. Not sure how you get £2700 - unless 1 of the 12 speed group sets works out cheaper. Very nice bike though.
You might get a cheaper build on the aether 9 alloy and there isn’t much weight difference - think the alloy is 300-600g heavier.
Is there a reason you want full sus rather than a hardtail? For your uses it sounds like a hardtail would be more suitable. Which would save you money and weight of course.
I was about to come and suggest a Cortex but you've already thought of it! I've got an Evol and have beaten some 10 year PBs around Thetford from my XC racing days. It wouldn't be my first choice for an XC bike of course but it shows that it's not holding my older lazier self back really. I expect a Cortex would be even better in that respect. 😃
Thanks all, similar thoughts then.
I ran a 26" HT from 2011 till last month but I've got a gravel bike for commuting and road/pottering about use, so fancy something substantially different that can still handle the odd commute. My era of FS seemed to suffer with weight and pedalling bob which sounds like it's much less of an issue these days, so thought I'd go FS.
I might drop Alpkit a message and see if they've any wiggle room, it's a shame the groupset seems to drag the mid priced Cortex down but guess something has to give.
The Marin is only available in Large, which is a bit borderline for me at 6' 2" but depending on CycleScheme surcharge means I've got some change for some T8000 Pedals and some upgrades. Bit frustrating it's not Microspline on the rear hub.
The Bird is interesting because (rightly or wrongly) it seems they'll let you pay the difference in C2W voucher and the cost. It seems like it's proper overkill for my needs but at least it'd be supporting a local company and seemed a genuine discount. Taking the fork down to the cheapest one and downgrading the brakes gets you to 2700
Worth remembering that Alpkit/Sonder (Like Bird iirc) build all their bikes to order so changing spec isn't generally a problem.
Aether9 alloy owner here. Fab bike.
Not a light short travel bike though. Mine is at least 15kg. ML frame. Pikes. Minions. Deore, 4 pot brakes, nukeproof horizon wheels, 200mm dropper etc.
The bargain frames they’ve had recently are very hard to ignore it must be said
I purchased an ex demo Cortex from my local store last year and its been brilliant, I was told it was used for a photo shoot and after giving it a good clean its like new.
I paid £50 for a demo ride (Refunded if you buy a bike) on the Evol and Cortex over a day and for me the Cortex was more fun, it also climbs really well.
I got the Cortex with the XT groupset which also had the forks upgraded to Cane Creek helm mk2 forks for £2200 after a bit of negotiation (My memory is a bit sketchy but I think it was up for £2600 originally), its well worth asking or putting cheeky bid in!
Don't forget to register as a member before making your purchase, you get 10% back in vouchers which give you money off in the future as well.
Saracen Ariel 30?
Thanks I'll contact Sonder/Alpkit tomorrow, I saw there's a store at the MetroCentre so actually seeing one in the flesh would be handy. As you say they might be amenable to changing up the groupset with the extra £100.
I think I'm getting drawn into the Bird only because it's carbon and because of the discount, rather than any actual need. It's probably daft to consider adding extra cost.
Ariel looks really interesting but similar kit to the Marin, but £500 more as a 2023 model?
“Main uses will be light rails, heading out with the kids and the occasional 20 mile round commute (so don’t want Enduro levels of travel).”
I’d get a nice hardtail for that! A modern 29er will seem a huge leap forward from your old 26” bike.
I want to try a FS and it gives me the option to do some trail riding (if time ever allows). My partner has a Liv Tempt 1 HT so though it's a little small for me, means I've still got the option in the house.
Now looks like a straight shootout between the Marin and the Pike-equipped Sonder - I can't use CycleScheme on the Ripley.
If it helps anyone else looking - There is a Bird build that comes in at £2500 but I think it's more bike than I need
Shimano Deore 12
RockShox Yari RC
SRAM G2R brakes
RaceFace non dropper seatpost
The Yari is quite a burly fork (Lyrik with a cheaper damper effectively) - the Aether 9 is really capable on difficult stuff. It potters ok but there are lighter bikes out there for sure.
On the Cortex if you could get the NX up to GX just on the cassette (but leave the mech and shifter) it gives you a bigger range and an XD freehub.
HG can only go down to 11t on the rear - microspline and XD go to 10t on Shimano and Sram. NX is HG.
Thanks Joe, I'm headed over to the Alpkit store this weekend. They wouldn't go up to GX groupset for less than £500 more, but will ask from a cassette perspective for the reasons you mention. I did see an online review mentioning they'd moved up to a Cane Creek rear shock but suppose I've only got £100 to play with so may just see if I can get the brakes upgraded instead.
Heard back re: the Marin and due to C2W overheads they'll do it for £2100. I think the Sonder with the Pike Ultimate is probably the better buy.
I remember your previous thread OP.
I reckon you should be looking at XC bikes if you want a full-sus. Not my area of expertise at all, but I'm sure there are deals out there now.
Maybe something like an Orbea Oiz, Scott Spark, Trek Top Fuel?
Thanks Chakaping. I was headed down the XC route with the Vitus but can't get hold of one until they reintroduce CycleScheme so think that's off the cards.
The Orbea and Spark 960/970 seem to be on offer around the £2k mark but think i might hit this C2W surcharge issue again, which then brings me back to the Sonder as a short travel trail/XC bike. The discount on the Pike Ultimate on the custom build seems to be worth the comparative savings on a 2022 Oiz/Spark. The obvious difference I can see on the XC ones is the ability to lock the fork and shock out; I'm finding it really difficult to find weight figures for some of them online but the Sonder is approx 14kg. The Oiz H30 is lighter but out of budget, where as the H20 is heavier.
Appreciate a lot of this is just me speaking out loud as it were, but seems like there's a small pool of bikes to look at, will have another comparative look at the Orbea range.
Fair enough.
A shorter travel XC bike may possibly still pedal better than a similar or lighter trail bike though.
To your point, JE James have got the Oiz H10 TR in stock in an XL for £2.6k so have dropped them a message to see if any top up/wiggle room.
Have got a quote lined up for the Sonder, though they didn't want to shift on any pricing (quoted £100 to swap just the rear mech to GX, which is more expensive than buying one seperately)
Looks like a really good spec.
I expect shops will be keen to do deals and get bikes sold at the moment, from what we're all hearing about the big overstock issues.
How about a specialized epic?EPIC
Not a FS but sure rides smooth - ive just come to one from a santa crzu hightower which was overkill for the trails and commute routes i mainly do.
To bring a couple of threads to a hopeful close, I've gone for the Orbea Oiz 2022 H10 TR. JE James didn't actually have stock but another retailer does, and after C2W surcharge it'll come out at £2855 (RRP was £3499 last year).
I wasn't totally happy with the compromise of the old HG hub on the Sonder, and the low spec SRAM brakes, though the fork looks absolutely top spec for the current £2399 custom build.
I think the Oiz is as lightweight as I can get in the absence of the Vitus being available and it's full of Shimano XT bits, with Deore brakes. As to points made on this thread (and the other one), thanks everyone, I think XC is probably right for me. I've seen an XL H30 in the flesh and while I'm slightly concerned about the longer reach, the standover height looks more than fine.
If that’s the one with the Fox 34 float fork and XT group set / 6100 brakes and the Raceface Arc wheels it should be very decent - especially coming from a hard rock 👌
So the Orbea has arrived and it's even nicer in the flesh, I've put the handlebars together, lubed the chain and fitted some new XT T8000 pedals.
Haven't had chance to ride it yet and I'm away the next couple of days, but sat on it in the garage like an excited kid on Christmas day...
One question I had - this is my first ever dropper seat post. The reach on the XL frame is fine, but even with the base of the seatpost inserted all the way, when I flick the lever for the dropper to rise, the max height is way to high for me.
Do I just have to use my weight to stop it going full extension or can they be modified to limit the travel, or do I need to budget for a new seatpost?
Tried Googling it, it's apparently "OC MC20 Mountain Control Dropper, 31,6mm, 125mm travel" but others suggest it's similar to a 'Brand-X' so presumably somewhat generic.
Thank you
You can't reduce travel on the orbea droppers so you'll want a 100/120mm or one you can reduce travel on. Brand X are very cheap at the mo. Have a good look at the diagrams to check stack height when choosing a replacement.
Oneup can be height adjusted - and one of the new Trans X posts can. Out of the sensibly priced seatposts (I.e not the Bikeyoke) the Oneup has the lowest stack height and you can normally adjust them by 20mm down from the full height in 10mm increments
Thanks both, will have to wait for another month financially. Presumably mine will have some resale value
I'm guessing that the seatpost will not insert all the way into the frame as only having the droppable 125mm (+ collar) of the post showing would be strange on an XL bike with you at 6'2? Most dropper seatposts are 125mm at the minimum (and lots of large / XL bikes come with 150-200mm drop posts).
In this case you need to measure how much insertion depth you have for the post and then how much 'external' post you need and go from there. Its all very well buying a lower drop post, but if it won't insert enough it's not going to be a solution (also consider this if getting a OneUp and reducing the travel, as the amount of post you have to insert into the frame won't change). One up have a handy guide to help with this.
Any cable post should work with your existing lever and you should get some money back from your Orbea one.
Cheers mate, I need to measure the whole thing when I'm back home on Friday, as it's more or less already on the seatpost clamp. Sadly only took one photo after assembly yesterday with the post at an "OK" height for me to put feet on the floor
When it's actuated and it's fully dropped it's obviously far too low to sit and pedal, so I'm comfortable the frame is an OK fit for me.
But I'm wondering if it's a longer drop than the quoted 125, on the XL frame? Only one way to find out.
[url= https://i.ibb.co/QbvBSZj/Screenshot-20230307-225717-Photos.jp g" target="_blank">https://i.ibb.co/QbvBSZj/Screenshot-20230307-225717-Photos.jp g"/> [/img][/url]
Orbea say the XL comes with a 150mm dropper here https://www.orbea.com/gb-en/bicycles/mountain/oiz/cat/oiz-h10-tr
So a swap to a 125mm might be what you need.
Easy enough to check what Phil’s update says. I’d measure how much post you have showing in the picture you’ve posted. If it’s 125mm+ you should be good with a 125mm post, loads of choice, Brand X being the budget choice. OmeUp have the smallest ‘collar’ if space is still tight. To check if it’s 150mm at full extension that’s just a case of pop all the way up and get your tape measure (as I’m sure you know anyway).
I’m surprised a XL bike has 125 rise dropper too
My M/L had a 150 XL was 150/175 I’m sure
Also if ye can find a Whyte dropper they can be modified similar to One up and a lot cheaper for the post
Thanks all, back home on Friday so will check then. Only thing to be cautious of is that the Orbea website is now showing the 2023 version and there have been a few spec changes to my 2022 model, but tape measure will give a definite answer.
with the post at an “OK” height for me to put feet on the floor
Why are you putting your feet on the floor if your saddle is at full peddaling height? That says to me that your saddle is not high enough for peddaling. If you want to put your feet on the floor, lower the saddle.
In case that post was ambiguous, "put feet on the floor" as in just being able to put the ball of my stretched right (usually) foot down on the floor when stationary.
Without going down a rabbit hole of bike fit articles.
Regardless, it looks like the answer is a different dropper.
Yeah it's a 150mm on the XL model as was called out. A bit frustrating as the XL was billed as being OK for people an inch shorter than me but I suppose we're all different builds aren't we.
100mm will do me absolutely fine, pretty much fully inserted. Ordered one from CRC for £50. Will dismantle current bits when it gets here as I need to figure out if I'll need to run a new cable, guess it depends on how it attaches to the existing one.
Thanks for all the help.
Have you not had a dropper before? I started at 100mm - got used to it then wanted more. So then I got a 120, then a 150, then a 180 and ended up with a 210mm dropper. I’m 5’9 but no point going to a 240mm as it would hit the back tyre of my bike on full compression I reckon.
I guess it’s different on an xc ish bike where you probably aren’t going to be sending it down a sketchy steep South wales off piste trail that makes you feel a bit queasy!
Hope the 100mm one works out for you - but you might have squeezed a little more in the space if it was only a little bit too high🤞
Nope, first time mate. Also first time buying a bike largely unsighted/untested, so lesson learned for me there (I did see an XL H30 in the flesh but didn't get chance to get on it).
Forgive any terminology mistakes but I've got the bottom collar of the dropper pretty much on on the main seat post clamp, so perhaps a size L bike would have done me OK and meant I could have used longer dropper travel, but what's done is done now and sizing chart wise, I was at the absolute top end of the L, and from test sitting on it in the garage until I find my spare helicopter tape, the reach feels good on the XL.
I got the tape measure out when I got back from London last night and stopped it at various lengths. The full 150mm puts me too high when pedalling and I can't get on and off the bike safely.
I could have just about squeezed a 125 post but I'm still at risk of falling off the bike trying to dismount, and worst case, I'll just shift the main shaft of the dropper post upwards slightly to compensate, at the cost of not being able to drop it as close to the top of the seat tube.
The joy of a dropper is you drop it to mount and dismount. So you can get the ride height perfect for pedaling .
Its been fab for me as I've got older and become less flexy .
just looked up the geometry and that orbea has a really long seat tube by modern standards (20.5") - I suppose it is an XC bike but still seems odd.. no wonder you need a shorter dropper.
just picking up on that again
you said ball of foot on floor with seat up?
I can't get anywhere near that, test properly. prop the bike against a wall, get your shoes and pedals on and see how it looks.
I think if I stop, seat up on any of my bikes I can literally tip toe the ground with the bike lent over
As someone else said set the seat up for pedalling efficiency, dismounting drop the seat. if you are unsure, get out and ride a bit, you don't need to put the seat all the way up, but it is easier and more user friendly if you do, but for a test ride it won't matter
if its your first dropper you may have become accustomed to riding with your seat at a less optimal height perhaps?
Thanks. Learning something new every day, hadn't thought to drop it to dismount each time but still need the substantial reduction in height otherwise I'll forever be fiddling. Glad to hear the bike seat tube is longer than expected.
I've ordered the 100 and will try the three of yours pedalling advice once I've got it fitted, as can probably move it up away from the seatpost collar a little too.
Just on saddle height it’s meant to be set for pedalling - not to make it easy to get off the bike.
I normally set saddle height up by having the saddle up to the point when the pedal is at the bottom of the stroke on one side my leg is just about straight - but not over extended. You should still be sat square on the saddle at this point. Any lower and you’re making pedalling harder for yourself.
Whenever I stop on my mtb I lower the saddle as I put my foot down. To the point I kind of miss the dropper when I’m on my road bike!
