Specialized do a 65mm but struggling to see any others in stock.
Any suggestions and experience please.
It is for a gravel bike and I'd like it flared. Current bars are 440 wide, and current reach of 80mm
These are 70mm reach and flared.
https://www.sigmasports.com/item/Zipp/Service-Course-70-XPLR-Handlebar/SRIO
Did you want alloy or carbon?
These are what I run on my gravel bike
https://www.sigmasports.com/item/PRO/Discover-Gravel-12-Degree-Sweep-Handlebar/L0DL
Or these specialized are flared
https://www.sigmasports.com/item/Specialized/Hover-Alloy-15mm-Rise-Plus-Flare-Handlebar/GMX2
Seems there are quite a few out there in the 65-75mm range
Ritchey Beacons, 65mm reach. Nice flare, wing top with slight back sweep. Love 'em
Good topic. I put a 60mm Cinelli Ant stem on my gravel bike if that’s useful info.
Cheers all, a few there to look over.
Probably alloy for budgetry reasons.
Pro Discover are a good shape with flare options between 12 and 25 deg. I've got the 25 deg version, I like them. 65mm reach.
Another vote for the Corralitos.
Ritchey Beacons, 65mm reach. Nice flare, wing top with slight back sweep. Love ’em
+1
Got 46cm ones on my gravel bike, getting a 52cm pair for my Cotic Cascade when it comes in.
I bought bars 44cm wide with a flare on the drops which is 54cm wide. I needed the 44cm over the 42cm bars that they replaced but the extra flared drop width becomes a problem fitting through tapered bike gates on cycle routes.
I reduced the reach on the same bike by buying a shorter stem. The shorter stem helped shift my position and weight over the rear wheel on descents.
