Short Chainring bol...
[Closed] Short Chainring bolts, Expensive or what?
Currently off the bike after an Op to fix my collarbone and decided to change from triple chainring, which I only use 1 ring, down to a single Works Components Thick/Thin 32t with Clutch Mech and believe I need to order some short chainring bolts.
Why are these so expensive £10-15 for 4 bolts seems pretty pricey even by MTB standards.
Anyone, suggest any good deals on these? I don't want to bodge it with washers etc..
Posted : 01/11/2013 4:56 pm
A set of 5 Stronglight chromed steel bolts retails at £7.99, coloured alloy ones a bit more. You'd likely get a far better price per bolt if you found the supplier and asked for a few thousand.
You could also spend an hour or so with a file shortening the bolts you've got.
Posted : 01/11/2013 5:02 pm
I got several sets off eBay seller , can't remember his name but think they were onza bolts in several colours, were bout £6. They look good and do the job.
Posted : 01/11/2013 5:11 pm
I've bought a few of these over the years
www.chainreactioncycles.com/race-face-replacement-chainring-bolts/rp-prod40501
Posted : 01/11/2013 5:13 pm
I just brought some for a fiver off these guys (also used them for all manor of bits and bobs, highly recommended) http://www.sjscycles.co.uk/
Posted : 01/11/2013 5:20 pm
@happyrider
Are they short bolts?
[url= http://www.charliethebikemonger.com/id-cromo-chainring-bolts---single-speed-double-and-extra-large-128-p.asp ]Charlie the Bikemonger[/url] has a set for a bit over a fiver.
Posted : 01/11/2013 5:23 pm
@Freester cheers for the link, want them in black tho... guess thats why they are a little more
Posted : 01/11/2013 5:25 pm
Cheers for the replies, going to take a punt on the Onza ones from eBay as I want coloured ones
Posted : 01/11/2013 5:26 pm
yeah was just going to say, this is one area where the lbs might be a bit cheaper. I've been in a few (2 in fact) and asked about chainring bolts and they've pulled a box full of different sizes and had to search through for mine and then charged a quid a bolt.
Posted : 01/11/2013 5:28 pm
Just bought the ones boardinbob has linked too and are nicely made and used on a single ring perfectly
Posted : 01/11/2013 5:45 pm
Yeah I'm using them on a single ring set up with no problems.
Posted : 01/11/2013 5:58 pm
Yes they are shorties
Posted : 01/11/2013 6:03 pm
I needed some when building my latest singlespeed, found some old titanium venhill items in my bit box, so turned them down on the lathe.
Posted : 01/11/2013 11:15 pm
Have you checked you need short ones yet? I recently got a single ring with no counter bore on the inner side (not a Works one though)and the Onza ones were to short when I tried them. (The inner bit didn't go through the ring to the crank arm....it would have tightened but it would have had no strength.
May not effect you but I thought I would mention it.
Posted : 01/11/2013 11:38 pm
