Short cage mech dou...
[Closed] Short cage mech double chainset..?
6 Users
Can I use a Sram x9 short cage mech with a 22/36 chainset and a 11-32 cassette or will I need a medium. I seem to remember a way of working this out could someone remind me please. Thanks Sam
Posted : 04/12/2011 7:28 pm
No, you will need a medium, i think due to the size of the rear cassette more than anything.
Posted : 04/12/2011 7:35 pm
A short cage works fine with a 32/11 cassette. Its more to do with the difference in size between the front chainrings I think.
Posted : 04/12/2011 7:36 pm
Ok thanks for replys, didnt think it would stretch to that.
Posted : 04/12/2011 7:37 pm
no you shouldn't, it is due to cassette size, not chainrings...afterall look at road bikes
Posted : 04/12/2011 7:44 pm
Surely its a combination of both? I'm assuming a (MTB) short sram mech is desinged for singe ring full size casette setups?
A 22-36T setup is a fairly big gap and an 11-32T casette isn't small either. I suppose it will depend on if you will ever use 36-32 and/or 22-11 also as to how much chain length difference the mech has to take the slack for?
Posted : 04/12/2011 8:14 pm
No, you do have to consider the rear cassette size, not just the tooth capacity.
I am pretty sure you cant run a short cage mech on any cassette where the largest cog is over 27t but you may get upto 38t at a push. the jockey wheel will hit the cassette otherwise.
Posted : 04/12/2011 8:19 pm
I was assuming a short cage (MTB) mech would be designed to run as single ring/full size casette setup (ie upto 34/36T casette) being an MTB mech not a roadie one, very much a personal expectation/assumption rather than the reailty of an X9 mech
Posted : 04/12/2011 8:22 pm
I've used a short cage Shimano mech with a dual ring (32/22) setup and standard 11-32 cassette.
Think a short SRAM is a little shorter than a short Shimano so be careful.
Posted : 04/12/2011 8:24 pm
