Shock pump for Reve...
[Closed] Shock pump for Reverb Stealth
New Reverb Stealth doesn't extend fully, maybe 10mm or so short - when I pull on the seat it rises the last bit.
Thought I'd try checking the air pressure and topping up if required, but my shock pump wont fit as the head is too fat to fit inside the seat tube and reach the valve.
Any suggestions of a cheap pump that will fit and can go up to 250 psi?
Thanks.
Si
Posted : 20/02/2016 10:58 pm
Standard Rockshox shock pump fits although a little fiddly.
Posted : 20/02/2016 11:49 pm
Please don't pull up on the saddle, it will probably make the problem worse- it tends to pull air into the internal hydraulics. Can't help you on the pump sizing, sorry
Posted : 21/02/2016 12:04 am
I checked my Reverb yesterday as I've never done so before. In 18 months it had dropped to 140psi.
Posted : 21/02/2016 12:33 am
Am going to get one of these - looks like it will work. Fingers crossed!
http://www.wiggle.co.uk/topeak-pressure-rite-connector/
Si
Posted : 21/02/2016 9:36 pm
My On One shock pump fits fine and was cheap if that doesn't work out.
Posted : 21/02/2016 9:38 pm
