Hi, I'm in the process of sending my BOS back to get a broken switch fixed, and trying to borrow a shock in the meantime.
The current shock mounts are 22x8mm front, and the rear doesn't have any eyelet bushings, bolts straight onto the mounting bolt, at 12.7mm wide x 15mm diameter.
Does anyone know if standard shocks have 15mm eyelet diameter, without eyelet bushings inserted?
Thanks
Posted : 04/01/2016 2:53 pm
