Shimano Zee 1x10
[Closed] Shimano Zee 1x10
just swapped from 1x9 sram x9 on a gripshit to 1x10 using SLX cassette and a Zee short cage mech and shifter..
works well (better then sram) shift is positive, clutch mechs actually are all they are cracked up to be and Zee seems to be a good option for 1x10 as you can get a shirt cage mech and only have to buy a right shifter - no lefhand to leave in the box.
Posted : 15/04/2013 10:52 pm
I liked mine too, only took it off as practicality dictated going back to double and the short cage was too short.
It's sitting wrapped in blue roll for the summer when I feel up to single ring again....
Worth mentioning that the shift seemed more SRAM like than Shimano but for intended use this might be a plus... ๐Ÿ™‚
Posted : 15/04/2013 10:57 pm
have a 32t chainring and 11-36 cassette at the back on my Singular Swift.. yes not a butter smooth as say SLX but def better than sram and no more lazy spring x-9 rear derailluer.
quite like the trigger very different to the previous gripshit.
also weights, quality etc seem similar to SLX.
Posted : 15/04/2013 11:00 pm
Iirc the part numbers are in the same range as SLX too ... ๐Ÿ˜‰
I ran mine with a 36 g ring and 11-36 with SLX shifter.
Was great but my legs weren't enough to let me get that lot up hills in The Peaks on snowy, muddy fields and I just spent so much miserable pushing time I went back to double for now. I've had a lazy winter so probs entirely self inflicted. Has been replaced with an old M665 minus bash and an XT Shadow M780 with the other SLX shifter and an M785 front Der for now. More metal but much easier climbing!
I have a Chameleon in pieces right now that either needs a fork rebuild or alternative forks but is a low priority as its not my only bike. When that goes back together that's where the Zee kit is going and I *will* conquer 1x10 before the year's out!
Posted : 15/04/2013 11:32 pm
was fine on 1x9 32 11/34 before so actually nice to have the 11-36 as you get a 32-36 rather than a 30-34.
Posted : 16/04/2013 9:48 am
