shimano slx 10 spee...
[Closed] shimano slx 10 speed chains.
5 Users
Am I correct in thinking that there's no reusable links which can be used on these? Anytime I take my chain off, I'll need to fit a new pin?
Lad in halfords said you can reuse the pins, but I noticed there's a small sliver of metal which shears off when you push them out, so I'm not sure it'd be a good idea...
Posted : 15/06/2013 7:30 am
Don't re-use the pins, if you're joining a Shimano 10sp chain either use the special Shimano joining pin, or even better use another brand's quick-link, like KMC.
Posted : 15/06/2013 7:35 am
 br
He's right in that you can, but I wouldn't as it can create a weak spot if you're not lucky - far better just buy a pack of pins.
Posted : 15/06/2013 7:37 am
Kmc make 10spd compatible quicklinks as do sram, both are removable/reusable using the KMC tool (£8) although the sram ones are supposed to be single use.
Reusing the pins will work as a trailside bodge if you have to but in my experience they will fail eventually.
Like [url= http://www.wiggle.co.uk/kmc-10-speed-chain-links/ ]this[/url] ?
Posted : 15/06/2013 7:48 am
Yep kmc do a twin pack and connex a single link pack, bothdo the same main difference is kmc you do need the reverse pliers to get it apart and the connex you can do with your fingers as I did last Sunday when I snapped my mech hanger off and had to walk back 😀 both are about £8 only thing of not is the connex has a slight curve which does have to follow the cog curver or it tends to jump gear on the small cogs ok.
Posted : 15/06/2013 7:55 am
Yes, but obviously the Shim/SRAM/KMC version not the Campag one. Might also want to pick up the special pliers referred to above, as they can be quite tight to remove when new.
Posted : 15/06/2013 7:56 am
