Shimano shifter kno...
[Closed] Shimano shifter knowhow please....
Hi, I picked up a set of SLX M670 shifters, so have no paperwork and cant find it online, so can anyone please advise setting the 2x10 mode?
On XT you have the front shifter set on 3x, shift to middle gear, then switch it to 2x.
Is SLX the same?
Ta very much....
Posted : 26/04/2015 3:34 pm
I don't know the answer to your question but you should be able to find out here... http://si.shimano.com/#seriesList/5
Posted : 26/04/2015 3:47 pm
Yes,
Mode convertor is located under the left hand shifter, it's important that you push forward on the down shift slightly as you turn the screw from 3x to 2x otherwise it won't go and you may break it, don't force it.
edit: Should also be in middle ring when adjusting.
Posted : 26/04/2015 3:59 pm
