Shimano 'Shado...
[Closed] Shimano 'Shadow' Rear Mech Which Shifter?
Hi someones given me a Shimano shadow rear mech, i know it needs more pull than a normal mech, so can someone recommend a shifter for it? 9 speed (if possible), a link would be good to where i can buy one too!
thanks!
Posted : 20/04/2016 4:22 pm
I might be confused, but you need to have the right speed shifter for the right mech, after that it's a matter of the nicest Shimano one you can stomach the price of?
Posted : 20/04/2016 4:30 pm
I'm not completely sure but I think the shadow mech is 10sp only?
Posted : 20/04/2016 4:34 pm
"i know it needs more pull than a normal mech, "
No it does not .
Just use a 9 speed Shimano shifter .
I have M970 shifters on two bikes . One bike has a standard mech and one a shadow .
Both shift exactly the same .
Posted : 20/04/2016 4:51 pm
There were 9 and 10 speed Shadow rear mechs. Assuming it is a 9 speed RD-M772 mech then any Shimano 9 speed MTB shifter will work fine.
Posted : 20/04/2016 5:01 pm
Get the mech model number then we can better advise you!
Runs to garage to check! makes sense, i bet its a 10 speed mech! be back in 5!
Posted : 20/04/2016 5:05 pm
Deore RD-M593!
Posted : 20/04/2016 5:13 pm
10 speed ๐Ÿ™
Posted : 20/04/2016 5:15 pm
Thanks to all that have answered couldn't understand why it wouldn't work now i know!
Will a Sram X5 Side Trigger Shifter 9 Speed work with it by any chance?
Same cable pull?
Posted : 20/04/2016 5:21 pm
Now you mention it, yes it might. I ran a 10sp Shimano shifter with a 9sp sram xo shifter. You need a spacer under where the cable is gripped on the mech. I think it's slightly less than 3mm but Google it.
Posted : 20/04/2016 5:53 pm
Just under 6mm
Posted : 20/04/2016 6:14 pm
Thanks i will give it a go!
Posted : 20/04/2016 6:30 pm
