Shimano ice tech ro...
[Closed] Shimano ice tech rotors, are they worth the extra weight?
I've been given a set of ice tech rotors 180mm which weigh 148g on my scales.
Being a bit of a weight weenie they are around 30g heavier each rotor.
Marginal gains and all that.
Will I notice the difference? Are they worth the extra weight?
Posted : 01/06/2015 9:53 pm
have you ever boiled your brake fluid ?
Posted : 01/06/2015 9:54 pm
Coming down walna scar bike packing there was definitely something cooking
Posted : 01/06/2015 9:57 pm
How much is 60gm worth?
Posted : 01/06/2015 9:58 pm
60g? Really!?
Posted : 01/06/2015 10:12 pm
Yes. 60g? Have a poo before you ride.
Posted : 01/06/2015 10:13 pm
A poo? Just blow your nose.
Posted : 01/06/2015 10:14 pm
I've got a decent set of ashima rotors on at the moment, just wondering is it worth changing for the extra performance vs the extra weight?
Thanks
Posted : 01/06/2015 10:16 pm
On what kind of bike?
If you don't already think they might be worthwhile for *your* riding, then they probably aren't needed.
Posted : 01/06/2015 10:24 pm
 nikk
[quote=darrenspink]Yes. 60g? Have a poo before you ride.
[quote=thegreatape]A poo? Just blow your nose.
Presumably, you are both sesible enough to know you should have a shite and blow your nose ANYWAY? Therefore it is an additional 60 grams. Doesn't sound like a massive amount by itself, but when building a light bike, it all adds up.
In any case, to the question, the Shimanos are known to melt when they get really got, so as well as being heavier, they are also rubbish.
Posted : 01/06/2015 10:46 pm
Salsa horsethief 29er that I use for everything from xc, snowdon, trail centres and bike packing etc.
I'm guessing they are not worth the extra weight then?
Posted : 01/06/2015 10:48 pm
If you think you'll benefit ie you're overheating your brakes and suffering performance loss then it's probably worth the weight, otherwise not. (None of my brakes need fancy rotors or silly pads etc to work properly, if they did I'd replace them with better brakes rather than put a sticking plaster on it, ymmv.)
Posted : 01/06/2015 10:51 pm
Whatever option you take, don't forget to adjust the pressures in your forks and shock. That 60g unsprung weight can have a huge impact on your suspension 'tune' which can be quickly rectified by tweaking your compression and rebound dampers.
Posted : 01/06/2015 10:54 pm
Use your already fitted brakes and dot 5.1 fluid
Posted : 01/06/2015 11:06 pm
darrenspink ยป Yes. 60g? Have a poo before you ride.
thegreatape ยป A poo? Just blow your nose.
I'd like to know where in west yorkshire you have a long enough descent to melt rotors ๐Ÿ™‚
Posted : 01/06/2015 11:08 pm
Personally I thought my Ashima rotors were garbage and ice-tech ones were decent, so i'd go for it.
If you've been given them, then why not try them out and if you don't like them simply swap back.
Posted : 01/06/2015 11:15 pm
I melted mine doing a rolling endo for a mile... ๐Ÿ˜€
Posted : 01/06/2015 11:24 pm
. Use your already fitted brakes and dot 5.1 fluid
Or just some decent dot 4 with a higher performance than 5.1 ๐Ÿ˜‰
Personally I stick with standard shimano XT. Tried lightweight rotors, didn't rate them, didn't trust them. Ice tech is fine if you don't mind the risk of premature failure and thin wear surfaces and higher cost.
No dodgy wear patterns that I have seen on other brands and nice stiff spiders to keep them true.
Posted : 01/06/2015 11:35 pm
Not if they're Shimano. ๐Ÿ˜ฏ
Posted : 02/06/2015 9:04 am
I personally don' think they're worth the money, I've never really considered the weight of them.
I'm sure the Icetech Discs and fancy finned pads have some effect on cooling, but after a week in the Alps on Boggo Deore, non-finned pads and discs I'm not sure in which blazing fiery corner of hell you'd need them. My boring old non-cooled braked worked perfectly and exactly the same way on the first run and the last.
Posted : 02/06/2015 11:46 am
Slight highjack OP, have you got a frame bag for your Horsethief?
Got one (Horsethief) last year and have a few trips planned this year. Would be interested in your set up for bike packing.
Posted : 02/06/2015 11:49 am
Shimano meeting - "Why let people use good quality Dot Fluid like Castrol SRF, when we can sell them finned pads and rotors with aluminium cores that melt on long descents"
Posted : 02/06/2015 5:11 pm
Yes they are worth it. Owner of a Spearfish. Which is a more weight weeny bike and it has them.
Posted : 02/06/2015 5:14 pm
If you don't need to blow your nose...
Clip your nails
Have a shave (if your clean shaven on your face/a girl, be a bit more creative)
Go gloveless.
Posted : 02/06/2015 5:21 pm
damascus - Member
Not unless you are riding downhill and even then.... I went from icetecs to Quaxar rotors, saving 180g for a pair IIRC, and just a minor discernable reduction in performance.
Posted : 02/06/2015 5:27 pm
If you save 30grams off 20 separate components,that's nearly a pound and a half!
Its almost impossible for non believers to be persuaded around to the weight weenie point of view though!
Posted : 02/06/2015 8:08 pm
It's rotating weight also, so worth more in weenie-points.
Posted : 02/06/2015 8:15 pm
if you save 30grams off 20 separate components,that's nearly a pound and a half!
Wow, thats like a bunch of bananas.
Posted : 02/06/2015 8:50 pm
If you're surviving on Ashima rotors, you probably don't need Ice Tec
Posted : 02/06/2015 8:56 pm
