Shimano i-spec B - ...
[Closed] Shimano i-spec B - where does it place the shifter?
I'm looking at going to 11 speed along with getting some of the XT 785 brakes which are now a bargin at £55ish an end.
The 785 are i-spec B which doesn't have the ability to rotate the shifter unlike the new i-spec 2 of the new M8000 XT.
So where does i-spec B place the shifter in terms of rotation around the bar? I tend to ride with the shifter rotated as close to the brake as possible (ie the brake limits me rotating the shifter any further) - how does that compare with where i-spec B places them?
TIA
Posted : 12/08/2015 10:38 am
It clamps onto the brake lever so the relationship between shifter and brake is fixed. My brakes are Hope Tech 3 so the relationship may be different to where the XT puts them
Posted : 12/08/2015 11:04 am
On your Hope, how close is the shifter to the brake?
Posted : 12/08/2015 11:07 am
 cp
sort of, you can slide the ispec mount on the shifter so you can move the shifter closer/further away from the grip (as if moving shifter inboard/outboard of brake lever clamp on a normal set up). no rotation though.... I've never found it to be a problem.
Posted : 12/08/2015 11:08 am
And I don't think it would be a problem - side to side is the adjustment I really want and what I find I can't get quite right with current car mounted shifter.
Posted : 12/08/2015 11:09 am
I've just gone from how you have them set up (rotated right together) to i-Spec B. It places them maybe 5-10 degrees further apart - leaving the big paddles rotated round slightly too high for my liking.
Posted : 12/08/2015 12:41 pm
Thanks Jon - exactly what I wanted to know - sound like I wouldn't get on with them then. Shame.
Posted : 12/08/2015 1:00 pm
I can take pics of my set up if you need it.
Posted : 12/08/2015 9:14 pm
Thanks but no need. I've just ordered the standard bar clamp for now.
Posted : 13/08/2015 10:03 am
