Shimano hydraulic b...
[Closed] Shimano hydraulic brakes road shifters
Do the above exist in 10 speed ?
in DI2 ?
Posted : 24/01/2016 8:42 pm
No
Posted : 24/01/2016 8:44 pm
As teeto, my understanding is they are switchable between 10 and 11
Posted : 24/01/2016 8:47 pm
Thanks, will drop Merlin an email.
Posted : 24/01/2016 9:10 pm
It does appear that I was wrong regarding the di2 ones. Definitely no mechanical option.
Posted : 24/01/2016 9:13 pm
It says 11 speed, are you sure they work with 10?
Posted : 25/01/2016 4:24 pm
As far as I know the Shimano DI2 parts only work in certain combinations, because they switched protocols and stuff as the technology "progressed". It would have been nice if you could just wire things up and have them understand each other, but that is probably not the case.
So, as it stands, no hydraulics for 10 speed.
l.e: Oh, and there's this gem: "Note: As of 8/3/14 firmware updates from Shimano remove the functionality between 6770 and 6870/9070 electronic components being used together. Some previous firmware versions allowed the below conversion to function without replacing the front derailleur, but firmware being installed as of 8/3/14 will irreversibly render such a mixed system dysfunctional. As of 8/3/14, a 6870 front and rear derailleur are both required to allow 6770 shift levers to work with an 11 speed cassette."
http://fitwerx.com/converting-shimano-ultegra-6770-di2-to-11-speed/
l.l.e: Vaguely related - https://twitter.com/internetofshit
Posted : 25/01/2016 4:31 pm
They're very much 11 speed Nick. I have them.
Posted : 25/01/2016 4:33 pm
Might have to see if I can change the freewheel on my Novatec hubs to take 11 speed then.
Thanks for all the answers.
Posted : 25/01/2016 4:42 pm
Ah yes, good point, well presented Simon.. ๐Ÿ˜ณ
Posted : 25/01/2016 4:50 pm
You may well be able to: I did the conversion on my Ambrosio hub, which is made by Novatec. A small amount of wheel re-dishing was required.
Posted : 25/01/2016 4:56 pm
Just leave a cog off the cassette.
Posted : 25/01/2016 4:57 pm
What rear hub do you have. I had 712s and 772s. You can fit an 11 speed freehub to a 712 but the back of the cassette rubs on the spokes. The 772 is 11 speed as std and you wont need to change the spokes.
Posted : 25/01/2016 6:50 pm
This works. I'm running the BR-R685 mechanical hydraulic set with the 14t (I think) removed, and an extra spacer slotted in. Seemed to shift okay on the two rides I've done thus far. My Stans wheel has a free hub which isn't upgradeable to 11 speed, but I wanted the hydro caliper. This will do me until I need new wheels.
Posted : 07/02/2016 9:30 pm
I was under the impression that any shifters (except, of course, the 7970 ones) can be used as long as the front and rear mechs are matched (either both 10 speed or both 11 speed). The mechs define whether it's 10 or 11 speed. [url= http://carltonbale.com/shimano-di2-everything-you-need-to-know/ ]Source[/url]
Posted : 09/02/2016 4:25 pm
