shimano hub bearing...
[Closed] shimano hub bearing replacement
need to change bearings in front and rear hubs and was wandering, is there likely to be anything else that might need replacing/worn inside the hub when this gets done? bearings are completely shot (slight side to side wobble and grinding noise)
cheers
Posted : 25/08/2010 7:18 pm
might find the hubs are shot 🙁
depends on the model of hub. the higher end hubs have replaceable bearing races, but the cheaper ones don't
if the races are pitted (inner is pressed into hub, outer is screwed onto spindle) then they must be replaced if you want to do a proper job
Posted : 25/08/2010 7:21 pm
saint m800 hubs, i got them like it and was wandering if its worth sorting them out or not
Posted : 25/08/2010 7:29 pm
need one of these then [url= http://www.google.co.uk/search?q=TL-HA20 ]Saint Hub tool[/url]
Posted : 25/08/2010 7:31 pm
yep for starters, hence why am wandering if it is worth doing or not. might be easier (and cheaper) in the long run to get a different set of wheels.
price of bearings too (not much i know but it all adds up), possibly cones maybe even a hub. i can't rebuild a wheel (never tried) so price could spiral out of control
Posted : 25/08/2010 7:34 pm
defo one for LBS imo. shouldn't cost to much to do, since it's easy to do in half an hour if you have the tools.
Posted : 25/08/2010 7:35 pm
Buy some superstar switch hubs and stick em on.
Posted : 25/08/2010 7:36 pm
got a quote of £60 - £70 to service hubs and replace bearings but if it needs other things too???
yeah, been looking at superstar website, thats what got me thinking is it better to replace then repair on this occasion?
Posted : 25/08/2010 7:38 pm
the shimano freehubs are what keeps me away, useless, the superstar hubs are excellent value, like cheap hope hubs. Same sorta design just lesser quality. Well made tho
Posted : 26/08/2010 1:13 pm
