Shimano HBM-765 and...
[Closed] Shimano HBM-765 and M 756 - freehubs swappable
they have different part numbers and one hub is a centrelock and the other 6 bolt but was just wondering...
I'm eyeing up the cheap shimano 765's as donors for my 756...
Posted : 08/03/2010 3:10 pm
 D0NK
No....I think, can't be bothered to look up the part numbers but the latest XT rear hubs use a different sized freehub (and freehub bolt) than the previous versions. Oh and they are rubbish, I get years/lotsofmiles out of shimano hubs normally, the FH on my XT wheelset died after only a few hundred miles, others have had problems too.
Posted : 08/03/2010 4:00 pm
Yes this has come up a few times, I [i]think[/i] it's the most recent xt hubs, apparently they last about 10 minutes and fit in a different way.
Posted : 08/03/2010 4:01 pm
Donk you are thinking of M770 / M775 if you have the bigger freehub body bolt.
Posted : 08/03/2010 4:07 pm
I did have a search on but didn't turn up anythign conclusive other than 'the part numbers aren't the same.
will look at the crc 36 hole ones as donors then...
Ah, Mark - are they swapable?
Posted : 08/03/2010 4:08 pm
 D0NK
Damn sorry yeah you are of course right. So 765 and 755 should be swappable afaik.
Posted : 09/03/2010 11:32 am
I don't think they are actually. I have a recollection of there being a fitting issue.
Posted : 09/03/2010 11:42 am
thanks for answering Mark and no worries.
Posted : 09/03/2010 2:37 pm
