Shimano gear outer ...
[Closed] Shimano gear outer query
What is the difference between 'SIS SP41' and 'SIS SP -'
have previously ordered SP41 but have received some 'SP-' with new brakes looks much the same !
Thanks
Posted : 23/07/2010 2:57 pm
ALL shimano is the same
Posted : 23/07/2010 3:05 pm
AHA ๐Ÿ˜†
Posted : 23/07/2010 3:14 pm
No it isn't.
There's 4mm, 5mm, then XTR/Dura Ace has a silicon grease or some such already inside the outer, which the others don't.
Posted : 23/07/2010 3:15 pm
You forgot 6mm ๐Ÿ˜›
Posted : 23/07/2010 3:18 pm
6mm is brake outer generally, not gear.
Posted : 23/07/2010 3:20 pm
Sooooo :
this stuff is 4mm btw
Posted : 23/07/2010 3:21 pm
SP is part of the part code for the outer. The complete code would be SP36/40/41 etc. so could be that you have been sent 41 & it just doesn't say it on the casing.
I really wouldn't worry about it & just fit it & ride.
Posted : 23/07/2010 3:25 pm
not worrying and am going to fit it tonight - just curious and someone here always knows the answer !!! ๐Ÿ™‚
Posted : 23/07/2010 3:27 pm
OP the only difference is size and grease. 6mm is free-er running.
goldenwonder - Member
Generally, yes, you can get 6mm SIS outer though.
Posted : 23/07/2010 3:32 pm
And SP40/50 only has grease in the logo'd end(so don't trim that end, and feed the cable in from there), SP41/51 is fully greased.
Posted : 23/07/2010 6:01 pm
