Bike Forum
2
Posts
2
Users
0
Reactions
211
Views
Is there any difference between the Shimano SM-AX65 and AX75 E-Thru Axles?
Part of my AX75 E-Thru Axle has broken (the splined part on the lever side that makes contact with the frame) but they are £40 to replace. Which seems a little steep.
The AX65 is cheaper so is there any difference? Alternatively what are the chances of getting one replaced under warranty?
Posted : 31/07/2014 3:15 pm
AX-75 is arguable XTR level (hence the 7)
AX-65 is technically lower spec (6 being XT level, say).
But will work just fine.
Posted : 31/07/2014 3:21 pm
Cheers brant, will try and source the cheaper 65 then
Posted : 31/07/2014 3:38 pm
