Shimano crank paint...
[Closed] Shimano crank paint stripping
[#9952989]
Hi,
Just bought myself used Claris cranks, for my do-it-all Charge Plug.
I'm a bit of a oldschool and prefer silver stuff on my bike.
Therefore thought I will give it a good polish to add some bling.
Crank is still on the way to me but already started tinkering how to strip the paint (?) out before buffing.
I believe it is painted, not anodised...
Cheers!
I.
Posted : 21/04/2018 4:37 pm
The easiest way would be buy some silver cranks, stripping those will be a fair bit of elbow grease, and you will need to keep doing it, as they will then oxidise.
Posted : 21/04/2018 4:58 pm
Easiest thing I've found is to take it to your local strippers/anodisers/powder coaters and bung them a fiver for them to dip/chemically strip it.  Not sure if it is powder coat of some type but very hard to remove with DIY chemicals.
Posted : 21/04/2018 5:48 pm
Thanks!
Valid point.
Silver, compact cranks, for Octalink...
Found some new but that will see me about 50 quid lighter. These I've bought for 8 quid.
And just preemptively, not interested in cranks with external bottom bracket bearings. They are rubbish.
Last Octa seen me through around 15k miles in various conditions.
Cheers!
I.
Posted : 21/04/2018 5:57 pm
I know one person who's polished up a set of cranks, just used fine wet and dry and a bit of patience followed by autosol, the result looks really good.
They don't really need sealing as unlike rust, aluminium oxide is harder than aluminium so naturally forms a protective layer.
Posted : 21/04/2018 6:19 pm
Can’t argue with a £42 saving like.
Posted : 21/04/2018 6:23 pm
Used wire wool to strip my black Deore cranks (and a Dremel with a wire brush fitting for the awkward bits), although I didn't polish them just left it raw.
It does take some elbow grease mind.
Posted : 22/04/2018 8:54 am
Wet and dry, start with 240 grit and work your way up to 1200.
Then use polishing wheels/ mops and soaps if you have them. This will bring them up to a mirror finish.
Finnish with auto sol or mothers metal polish.
Posted : 22/04/2018 9:40 am
Don't strip too much off them, they might weaken and then catastrophically fail
Posted : 22/04/2018 12:00 pm
