Shimano BL-RX810 "d...
Shimano BL-RX810 "dual control" GRX lever; have I goofed?
Hey all,
I picked up a pair of GRX brifters the other day, comprising:
1 xย GRX RX810 11-Speed Dual Control Lever/RX810 Hydraulic Disc Brake
1 xย GRX RX810 Dual Control Lever/RX810 Hydraulic Disc Brake (Left- Rear)
these are to replace an aging and decrepit 2 x 11 105 hydro set that were falling apart.
Anyroads, I'm just fitting them and, much to my surprise the left-hand 'dual control' appears to have a single lever, much like SRAM 1 x. Which is disappointing as I used the LH 105 brifter to pull a dropper post.
Have I made a spectacular miscalculation, or is in fact a "BL-RX810" lever just a brake lever and nothing more?
ta
cb
Posted : 16/10/2023 6:47 pm
Does the brake lever blade pivot inwards? There wouldn't be a need for a second lever as that is only required for shifting. Quick search for pics shows no second lever for the dropper brifter.
Posted : 16/10/2023 7:30 pm
Yes, that's just a brake lever.
the https://bike.shimano.com/en-EU/product/component/grx-11-speed/BL-RX810-L.html
The st-rx810 is 2x shifter/brake and theres also a dropper specific variant tooย
Nixie- it does not.
Slacbkboy- thanks. The 'dual control' thing confused me. (What does that even mean??)
Back to the workshop....
thanks all
cb
Posted : 16/10/2023 7:51 pm
seems a bit shitty on Shimano's behalf to me, describing a brake-only lever as "dual" anything.
Posted : 16/10/2023 8:13 pm
The dropper specific lever is the one you want but you still need to bodge it if the nipple is at the wrong end for your post.
Posted : 16/10/2023 8:23 pm
Cheers. Yes, I've had successful dropping on a 105 dual lever for some time on this monstercross bike. All it needs is a solderless nipple at the post's actuator. These GRX levers are only going in because my ancient right hand shifter is getting a bit dilapidated, else I wouldn't be changing.
Posted : 16/10/2023 8:52 pm
 a11y
Shimano GRX RX810-LA is the 1x, dropper-specific lever that you want/need. It took me a ****ing age to understand the versions (first dropper bike for me).ย
As @rOcKeTdOg says, if your dropper has the nipple at the seatpost actuator end you'll need to bodge it as the GRX lever needs the nipple at that end. I was lucky that my older Brand X dropper I'm using has a cable barrel at the actuator end - you can also buy cable barrel thingys to add yourself.
Posted : 16/10/2023 9:39 pm
Thanks- yeah, as said above I've surmounted this issue already using solderless nipples, but cheers.
Posted : 16/10/2023 10:09 pm
