Shimano BB plastic ...
[Closed] Shimano BB plastic rubbish adapter- anything better?
Are there any decent value tools for newer Shimano xt mt500 bottom brackets, those plastic ones are rubbish for removing anything remotely been left in over winter , just stripped both I had.
Posted : 23/03/2018 8:16 pm
I have an IceToolz one which works fine
Posted : 23/03/2018 8:23 pm
 geex
if it's for a knackered one use the Harry Main method.
Big **** off pipe grips
Posted : 23/03/2018 8:25 pm
Park BBT-59.2
Posted : 23/03/2018 8:36 pm
Grey which ice tools one is it as I’ve read bad reports of the park one being like cheese?
cheers.
Posted : 23/03/2018 8:40 pm
..and don't forget the anti-seize on the threads (or a little grease if you don't have any). May be obvious, but surprising how many people don't..
Posted : 23/03/2018 9:33 pm
Well that is an issue.  my one says M093 on the side and it fits bbs that would need the horrible plastic thing with a standard HTII tool.  Assuming Shamano just do the two sizes for mainstream bits, that would be it.  It has 16 teeth and is 40.7mm  internal diameter (on the smooth bit).
I use the Shimano steel socket tools, Park do alloy ones;
Shimano TL-FC37 BBR60, MT800 etc 6 notch 41mm OD cups or Park BBT-59.2
Shimano TL-FC34 Dura Ace 9000, XTR BB 93 etc 16-notch 39mm OD cups or Park BBT-49.2
Thats for the 2 "new" smaller hollowtech BBs
Posted : 23/03/2018 10:28 pm
asbrooks reacted
