Shimano Am45 trail ...
[Closed] Shimano Am45 trail shoes ?
Hi guys
Needing a pair of spd compatible trail shoes(need some ankle protection) are there any others I should consider ?
Cheers 😀
Posted : 01/06/2014 10:36 pm
I have AM45s and love them, very weather proof, comfy and look good. picked them up for £40 from evans.
Only con is they're very heavy.
And I sized up 2 sizes, come up very small
Posted : 01/06/2014 10:42 pm
Happy AM45 wearer here too. Can't say I've thought they're small. Mine are the same size as any other shoes I buy.
Posted : 01/06/2014 10:46 pm
Thanks for info guys good to hear ... Are they really heavy ? Bit hot on warm days ?
Posted : 01/06/2014 10:52 pm
Much heavier than XC disco slippers obviously but they do feel heavy when picking them up. haven't had any troubles with overheating
Posted : 01/06/2014 11:02 pm
I have AM41s, the flat version. I bought a size up due to the "perceived wisdom". They are spacious. They don't seem particular warm or heavy to me. Very easy for Mrs S. to clean too.
Posted : 01/06/2014 11:18 pm
Cheers ... Guess the weight isn't really an issue when I'm winching a 30lb sled uphill 😆
Posted : 01/06/2014 11:21 pm
Disappointing shoes imo
Heavy yes but not particularly stiff for a SPD shoe. Uppers too flexible. laces are attached to the shoe by fabric loops which wear through and break. No metal eyelets. Laces too long.
Otherwise ok
Posted : 02/06/2014 8:03 am
I had some, came up far too small, and the sole is so fat I had difficulty unclipping. Sacked em off and got some flats. Anyone want some two ride old trail pedals?
Posted : 02/06/2014 9:21 am
mine weighed 1.5kg the pair after a wet commute this morning
i like mine, however they were my first foray into MTB SPD's - about to jump to something lighter for dry xc duties, however for wet peaks days ill keep the AM45s
Posted : 02/06/2014 9:24 am
I have had a set of AM45s for about 18 months.
I found them a good all round shoe but agree that they are very heavy and my feet did get overly warm in anything over 20C but generally that's not really an issue in the UK is it.
Didn't have any issues with the laces or the lace loops.
They aren't super stiff carbon soled disco slippers but on the plus side you can actually walk in them!
Posted : 02/06/2014 9:52 am
regarding the laces, i tied mine once, and just squeeze my feet in and pull the velcro top section tight
Posted : 02/06/2014 9:54 am
If you're coming from disco slippers they'll feel heaving and flexy.
If, like me, you're coming from 5.10s the AM45s feel quite light and stiff in comparison.
Sizing comes up a little small, the flap over the laces makes them more weather proof than 5.10s. Laces are longish but double knotted fit happily behind the flap.
Looks wise they're not too wacky for post ride pub.
My only complaint is that I've now had 2 pairs and sole has started to come away from the shoe at the toe end. I thought this was due to doing a bit of trial building in my 1st pair but the 2nd I've looked after and still had the same problem.
Posted : 02/06/2014 10:07 am
Mine are 'ok', but nowhere near as good as the old MP66's i have. They replaced the mesh on the MP66 toe with holes in the sides of the AM45 which let in water quicker I find.
Oh and I bought the right size and they fitted.
Posted : 02/06/2014 11:03 am
