Shimano 105 11 spee...
[Closed] Shimano 105 11 speed flat bar shifter
Hey all,
I'm looking to set up my RoadRat in a 1 x 11 guise as the rear mech, chain and cassette are all reasonably priced.
However I can't find an 11 speed flat bar shifter - they definitely make one, but no one appears to stock it.
Any ideas?
Cheers,
Paul.
Posted : 27/04/2015 12:07 pm
Do they? Nothing listed on madison.
Edit: Tell a lie, they do the SL-RS700 but looks like only as a pair. Currently out of stock, expected availability tomorrow though.
Posted : 27/04/2015 12:10 pm
Microshift plus paul components flat bar converter?
Posted : 27/04/2015 12:41 pm
£109 for a pair of the rs700.
http://www.buckinghambikes.com/shimano-ultegra-sl-rs700-flat-bar-shift-levers-
pair-black.html
or £59 for an XTR from Evans.
I assume XTR 11 speed will work with 105 11 speed?
Posted : 27/04/2015 12:56 pm
As far as I know it won't.
Posted : 27/04/2015 12:58 pm
ah. Why's that then?
Is 105 ten speed compatible with MTB shifters?
Posted : 27/04/2015 1:14 pm
Different pull ratios for road and mtb 11 speed mechs (at a guess).
Posted : 27/04/2015 1:15 pm
No
Posted : 27/04/2015 1:17 pm
Well, I shall abandon that project then.
Posted : 27/04/2015 1:24 pm
If you do revisit it in the future then also bear in mind that your rear wheel will need to be road 11spd compatible to run 1x11.
Posted : 27/04/2015 1:26 pm
Well, you completely nerfed that one Simon. I shall get my coat.
Posted : 27/04/2015 1:35 pm
