Shifters; inconveni...
[Closed] Shifters; inconvenience by design, at no extra cost...
How come brake leavers have a clamp design that allows them to be fitted to the bars without having to remove the grips, but shifters don't? If it's just to get on my ****in' tits...job done 😀
Posted : 21/09/2010 9:16 pm
sram x9 and avid matchmaker 😆
Posted : 21/09/2010 9:17 pm
sadly not all brakes do either, such as my new M775 XTs which is a shame when cheapo stuff can manage it...
Posted : 21/09/2010 9:32 pm
Don't understand why BMX lever style hinged clamps aren't used all round.
Posted : 21/09/2010 9:39 pm
Maybe they just presumed that everyone had seen the light?
Posted : 21/09/2010 9:43 pm
It isn't just the grips, you often end up with scuffed bars too.
Posted : 22/09/2010 7:24 am
To keep the weight down?
Good point though 🙂
Posted : 22/09/2010 7:37 am
How often do you need to remove your shifters? Assuming you set the controls up properly to begin with, probably not that often. I suppose it's a pain but then I don't take my shifters off that often so I can live with it.
Posted : 22/09/2010 7:44 am
Uplink, if you think lock-on grips are 'the light', it must be a very dim world you inhabit!
I'm gonna pop these new shifters on, inboard of my brake leavers. However, being the inquisitive sort, I might decide to try them t'other side of the brake leavers at some point, just to see. Then my contrary streak will get the better of me and I'll probably move them back.
With a removable clamp, I can dick around with the minimum of fuss:-
1. remove old shifter
2. fit new shifter
3. move shifter
4. move shifter back
5. sit around scratching myself
Even with the shining beacon that is lock-on grips, with a non-removable clamp it goes something like this:-
1. remove grip
2. remove brake leaver
3. remove old shifter
4. fit new shifter
5. fit brake
6. fit grip
7. remove grip
8. remove brake
9. remove shifter
10. fit brake
11. fit shifter
12. fit grip
13. remove grip
14. remove shifter
15. remove brake
16. fit shifter
17. fit brake
18. fit grip
19. have nap
I take the point about not actually having to do it that often in reality, but my point is, we shouldn't have to do it at all. It's just an additional mundane chore that I can do without! I don't buy the weight argument, it's less than minimal in the big scheme of things.
Sram X9 you say? Will it wotk with an SLX rear mech? Don't worry, I'll search it...bound to have been asked about a gajillion times before!
Posted : 22/09/2010 8:34 am
Yes it is a pain, although once the shifter is fitted if your brakes have the easy fitting thing you don't need to take it all off just to move your shifters to the other side because you can loosen the shifter to move it and take the brake off to move that 😉
Posted : 22/09/2010 8:37 am
Well how often do you need to remove your bars? Not very often either but the most stems allow you to unbolt the clamp to lift them out instead of sliding them out like you used to have to do in the old days.
Workshop mechanics love to see stuff that comes apart easily or is easy to change or service and hate stuff that isn't coz the same job takes twice as long.
Yeah Shimano shifters pee me off with their clamp design, sure it's not a massive inconvenience as you don't move them around often but it would still be useful to have a split or hinged clamp and presumably wouldn't add much to the cost for SLX/XT/XTR
Posted : 22/09/2010 8:43 am
becky_kirk43 - Member
Ha ha...good point! This has clearly got me so worked up I can't even think straight 😀
Oh, and becky...nobody likes a smart-arse! 😉
Posted : 22/09/2010 8:44 am
But what if you r brakes are in a nice comfortable place and you dont want to risk moving them because it COULD take 20 mins extra faf to get them right again.
A hinge/extra bolt IS the way it should be I cant believe nobody has done it yet.
Posted : 22/09/2010 9:25 am
lighter weight, simple manufacture, cheaper.
Posted : 22/09/2010 9:29 am
But it wouldnt be much heavier and it wouldnt be much more complicated to produce. But it would be much easier to fit and remove.
Posted : 22/09/2010 9:43 am
TandemJeremy - Member
Oh, phurleeease! Any weight increase will be sooo minimal that unless you're an anal gram-counter it doesn't even register.
Simple manufacture? For the likes of Shimano? Get outta here...we're talking an extra bolt ffs!
Cheaper? For the likes of Shimano? Get outta here...we're talking an extra bolt ffs!
Pennies, in the big scheme of things, pennies...
Posted : 22/09/2010 9:46 am
Just think yourself lucky its not a road bike like mine, with the old one bolt quill stem. Now [i]that[/i] is a pain in the arse!
Posted : 22/09/2010 9:48 am
 tang
like all good nerds i measure the position of the controls relative to the end of the bar when its all sweet, then promptly loose the bit of paper. in my own defence i have memorized my saddle height.
Posted : 22/09/2010 9:50 am
Is your life so close to perfect thats the only rant you could come up with?
You read the guardian don't you?
Posted : 22/09/2010 9:53 am
 tang
i read the guardian and my life is only 'nearly' perfect. its the curse of being middle class.
Posted : 22/09/2010 9:57 am
Rusty, you forgot the bar ends.
You do use bar ends, don't you ? 😉
Posted : 22/09/2010 10:28 am
Obviously not from a finance, engineering nor manufacturing back ground then
Posted : 22/09/2010 12:51 pm
votchy - Member
Nope. From a layman's perspective, Shimano (bikes) raison d'être is the evolution and improvement of bicycle bits 'n' bobs. The company will be structured to do this in an efficient cost effective manner. I struggle to comprehend how adapting, existing, tried and tested design, such as a split clamp with an extra bolt, is going to radically impact their R and D or tooling costs! I’m all ears if you want to educate me…?
MidlandTrailquestsGraham - Member
You do use bar ends, don't you?
😀 not at the moment...but I do have some old x-lite stubbies to call on if the urge takes me!
Posted : 22/09/2010 2:58 pm
Oh come on, Shimano probably spend more on their factory xmas party than Formula spend on manufacturing their brake levers in a year yet Formula can manage to do a split clamp (and brakes are more usually the subject of weight weenie attention than shifters). Given the trend for bumping up prices a fair bit each year I'm sure they could pass on the additional cost without anyone noticing (ofc 10sp redesign would have been a perfect opportunity for this but I'm guessing they're still not split clamp?)
Posted : 22/09/2010 3:28 pm
 tang
think the new xtr brakes are split clamp, trickle down? yes please.
Posted : 22/09/2010 3:29 pm
