Shifter cable lube ...
[Closed] Shifter cable lube options
Im going to service my cables tonight as winter grot has taken its toll on shifting. The last couple of times I just replaced everything. but since I bought XT last time I want to try and be less wastefull and just clean them out.
I have never been a big fan of oiling cables - in my experiance they last longer dry as the oil atracts filth or at best just gets washed out. But since the cables arent new anymore I have been pondering what else I have in the garage that might work better.
My initial thought was dry motorcycle chain lube. Anyone tried dry lube before? I intend to spray a load of degreaser down the outers first.
Posted : 29/01/2013 3:11 pm
Not sure about others but Sp41 seems to come with a silicone based lube inside which is probably why they say not to use any lube in case you use something that won't mix. I believe them to be silicone lubed as the inner liners are plastic.
Rock n roll do a lube which they market for cables. Might be worth a look.
Posted : 29/01/2013 3:14 pm
It will have to be something in the garage - not buying yet another expensive little bottle of "snake" oil containing (as near as makes no difference) exacly the same stuff as the last little bottle I bought.
I do have some silicone grease though - the dry lube could be too?
Posted : 29/01/2013 3:31 pm
Personally I'm a big fan of SP41 in terms of fit-and-forget but I have a couple of bikes with interrupted outers and on these I use household polish on the exposed sections.
Posted : 29/01/2013 3:36 pm
Hmm, I have heard of polish - I think the Mrs sometimes talks about it. Il see if she has got any.
Posted : 29/01/2013 3:39 pm
SP41 cable outer comes pre lubed with Shimano's special silicone grease so when I'm fitting new cables I use Servissol silicone grease to lube the outers and inners. The rest of the time I use Middleburn cable oilers and silicone spray lube to keep them like new
Posted : 29/01/2013 3:58 pm
dry lube is normally PTFE in a solvent carrier.
If you have some silicone grease I would use that. Best thing for lubricating metal on plastic and water and oil resistant (resist wash out)
Posted : 29/01/2013 4:03 pm
cheers
Posted : 29/01/2013 4:07 pm
cablemagic is good stuff. I use a syringe to get the stuff down into a new outer.
Posted : 29/01/2013 4:36 pm
