SFN whacker-inner b...
[Closed] SFN whacker-inner borrow in Chelt/Glos area?
I'm fitting some new forks, anyone in the Chelt/Glos area got a Star Fangled Nut whacker-inner tool that I can borrow?
If you've got a crown race smacker-downer that would be cool too.
Biscuits of choice can be supplied in return ๐Ÿ™‚
Posted : 10/02/2011 1:15 pm
20mm copper plumbing pipe and a mallet - what else is there to "need"?
Posted : 10/02/2011 1:59 pm
these are a much more elegant solution and are whack free;
Posted : 10/02/2011 2:00 pm
screw the headset bolt into the SFN and **** that into the headset ๐Ÿ˜€
Posted : 10/02/2011 2:13 pm
If you're worried you'll bash it in squint, try this... Get a bit of threaded M6 bar (or a really long bolt, I use some random bolt out of a motorbike engine) and find an M6 washer about the same size as the inside of the steerer. (make sure it can fit through the bottom, some steerers narrow). Then, thread the bolt/bar through the SFN so it sticks out the top by enough to hammer on, and drop the bar with the washer into the steerer. Et voila, hammer in, impossible to get it squint.
Posted : 10/02/2011 2:16 pm
Never, ever, managed to get a Hope HedDoctor to work....
Posted : 10/02/2011 2:21 pm
 nuke
[i]Never, ever, managed to get a Hope HedDoctor to work....[/i]
๐Ÿ˜• They're not complicated. Have them on all my forks...never had a problem
Posted : 10/02/2011 2:29 pm
ID on some steerers is too narrow...
ID on some steerers is too big...
I've tried them on a couple of frame / fork combos and found them to be a PITA
Posted : 11/02/2011 10:05 am
 Goz
Drop your forks into cc and i'll do it whilst you wait.
Posted : 11/02/2011 11:45 am
Raises the question, would you lend an impact tool to someone who called them whacker-inner and smacker-downer? ๐Ÿ˜‰
Posted : 11/02/2011 12:04 pm
Cheers Goz. I've just got a cheap Hed Doctor from the classifieds, but would you mind putting the crown race on?
If so, what would sirs choice of biscuit be? ๐Ÿ™‚
Posted : 11/02/2011 12:07 pm
[i]Raises the question, would you lend an impact tool to someone who called them whacker-inner and smacker-downer?[/i]
I'm sorry, am I confusing you with these technical terms? ๐Ÿ™‚
Posted : 11/02/2011 12:08 pm
Bribery and corruption will get you everywhere ๐Ÿ˜†
 Goz
I,ve a liking for the good old custard creams, bring the forks in anytime you like.
Posted : 11/02/2011 12:13 pm
Reminds me of the Halfords mechanicl when I was a kid who called the front mech a "double clanger".
Posted : 11/02/2011 2:38 pm
