Hi,
Is the basic servicing of these forks with the fit damper (clean inspect oil / dust seals, lube & new oil) the same as older models? Does anyone have any links to any good servicing manuals?
No, I haven't trawled through the Fox web site yet ๐ Though a basic search didn't come up with anything.
ta,
andy
Posted : 07/04/2010 9:30 am
Same as before except you can't replace the damper fluid without a complete strip down of the FIT cartridge.
Fox service pages [url= http://service.foxracingshox.com/consumers/index.htm ]here.[/url]
Posted : 07/04/2010 9:35 am
Yep, same as other models, let air out, turn upside down, unscrew bottom nuts, remove crush washers, put nuts on a bit, use a socket and give a tap, pull lowers off, clean and re lube foam rings, seals etc., put back together. Dead easy.
Posted : 07/04/2010 9:39 am
