Setting Sag; Sit or...
[Closed] Setting Sag; Sit or Stand?
 marc
After a fun moment of somersalting over a suprise endo yesterday, I think I should really take time to set up my new forks properly.
But, in setting sag for forks should you take the measurement for sag while you're standing in your "normal" descending pose, or while you're sat on the saddle?
A quick google shows differing views.
Posted : 08/11/2010 10:46 am
No definitive answer? Setting sag is not an exact sceince an any event, you gotta ride it and see what works for you.
Posted : 08/11/2010 10:47 am
[i]A quick google shows differing views. [/i]
you'll get a similar view on here 😉
me - for an xc bike I tend to do it sitting but for something a bit more hardcore, 'attack' position.
I do standing as a starting point. Then you have to go and ride and decide whether it was too stiff or not. Sometimes is good to go for a ride with your shock pump for the express purpose of setting up your forks.
I sometimes get on the bike and roll down the road a bit, out of the saddle, to see where the sag mark is. It's easier than leaning against a wall or something like that. Then I just go by visual inspection and gut feeling.
Posted : 08/11/2010 10:59 am
'attack' position
Posted : 08/11/2010 11:01 am
i find that if i do it sitting when i stand up then i'm too far into the travel - if i do it standing it's too stiff sitting.
depends on the bike but i prefer standing.
Posted : 08/11/2010 11:04 am
When i set mine i wear the kit i would normally wear on the trails on that Bike, that way the sag is set to your riding weight.
Posted : 08/11/2010 11:06 am
 marc
Not suprised after getting rear ended this morning! 😯
Hope you're OK
Posted : 08/11/2010 11:09 am
I always find that if I set it when sat it's way too much when stood, which is the position I'm normally in when I require suspension to be working to its' best.
Posted : 08/11/2010 11:20 am
I do mine when I'm standing otherwise it's way too soft.
Posted : 08/11/2010 11:35 am
Measure both and take the average, you will create more leverage on the linkage and shock when sat down, in this instance the higher percentage of your mass is distributed through your booty via the saddle, when you stand your mass is distributed through the feet via pedals/cranks/bb and this has less impetus/leverage on the linkage and shock, ie you will see more “droop/sag” when sat than when standing.
Posted : 08/11/2010 11:38 am
