Setting fork sag -S...
[Closed] Setting fork sag -Stand or Sit
If I sit on the bike correct sag comes at around 60psi which is way too low from a diving / bottoming perspective.
If I stand on the pedals ( the "attack position" crap phrase that) it's around 110 which seems way too hard.
I'm going to run around 85 which seems a sensible compromise or have I got it all wrong?
Posted : 16/09/2009 10:53 pm
IME sag is a pain to set - If I achieve sag when sitting on the bike I blow through the travel too quickly and find 25% too ambitious on forks less than 130mm - 10% more realistic IME
Posted : 16/09/2009 10:54 pm
Try 85, if it doesn't work adjust accordingly - its not an exact science, more trial and error FWIW
Posted : 16/09/2009 10:55 pm
sag is only a starting point, 85 seems a good compromise
Posted : 17/09/2009 6:51 am
I always thought that setting the sag whilst in - MBR stylee - 'attack' position was the way to do it
arse off the saddle leaning forward sort of stance
Posted : 17/09/2009 7:05 am
Both are viable methods as it's only a starting point. However, seated position os normally with 25% sag and th attack position is for 33% sag. I normally start with the attack position method and fine tune it with a zip tie or o-ring on the stanchion.
If I don't gte full travel on a Peaks ride, it's too firm. If I feel it bottom out harshly, it's too soft.
Posted : 17/09/2009 7:14 am
dunno, magura's have a very fine line between overly firm and wayy too wallowy. So I just set it about right then took a shock pump out and played about 5psi at a time untill it felt right.
Static sag should be set in the "attack" position (I hate that phrase too). Most people/bikes seem to be set up with nowhere near enough sag, how is 10% sag going to give you any more grip thana rigid fork, you'd have to hit 10G to bottom them out!?
Posted : 17/09/2009 7:39 am
Sit - read the manual!
Posted : 17/09/2009 8:52 am
 Olly
closer to stand.
**** the manual.
if i put mine on 25% sitting, i blow right through the travel, its just veyr plush for climbing sitting down (which is as good as useless)
25% at riding position, if your riding sitting down, your gay (in the rubbish sense, not the homosexual sense)
i run mine a bit hard still, so i can ride harder but still feel supported.
pretty close to the rockshox reccomended pressures actually (which i initially thought were way out)
Posted : 17/09/2009 8:57 am
Agreed, **** the manual - do it standing. I transfer enough weight over the front when standing/descending to eat up half my travel when I use set to 20% when sitting. I always set rear sag when sat though as I feel it gives better ascending performance.
Posted : 17/09/2009 9:00 am
but maybe you could ride harder if you had it softer.
Posted : 17/09/2009 9:03 am
I see I'm not alone in this. I'm a big guy and if I have 20% sag when sitting I'm around 60% sag when standing on the pedals, if I'm going downhill as well I'm basically on rigid forks.
Thing is set the forks up for standing = almost no small bump compliance but then I suppose that's the price of pies!
Posted : 17/09/2009 9:07 am
We need to have this fella gender tested ๐Ÿ˜‰
Posted : 17/09/2009 9:48 am
