Servicing Thudbuste...
Servicing Thudbuster - adding shims to reduce play?
Dug out my old Thudbuster ST for the gravel bike whilst an angry S.I. joint calms down.
Certainly makes a difference and so long as I can get over my sub-10kg bike weight obsession it seems like a worthwhile addition.
But it rattles. After not much use and after always having been protected by a Thudglove. I'll buy the service kit but it has already been serviced once FOC as a warranty thing, don't know if I've just got a bad one or some sort of excessive clearance exists between the linkages. Could I just add extra shims to take out the slop?
Posted : 08/07/2022 11:35 am
 kcal
Not sure, but my Thudbuster (donated FOC..) has transformed the ride on my Kona SS - makes it less of a pummelling. They're not light, but find it really good at easing out the sharp edges of a rigid bike.
Posted : 08/07/2022 3:24 pm
I think the slop comes from worn bushings and they can be replaced
Posted : 08/07/2022 4:47 pm
I have plenty of experience with thudbusters as I own 3 and have them on all my bikes ( LT version ) . Yes they do seem to get "wobbly" quite quickly as a result of the bushings wearing rather quickly ...in fact I was annoyed to find that recently ..even after fitting a new set they can show play at the pivots and I can't believe that's due to the pivots themselves ..must be poor bushing tolerance . I have replaced them perhaps half a dozen times in total now and I'm always frustrated by the cost of a few tiny parts and been meaning to try and source the bushings elsewhere . They do seem to last longer with occasional lubing . I don't use a cover but keep stuff clean . A guy came up with a modification to slow the wear rate but a cover must do the same I'd imagine . link to the modification
Posted : 09/07/2022 9:58 am
Thanks Kaiser.
I don't know much about suspension and linkages, but maybe this is one of those situations where if you let the bushings wear they then wear the pivots as well?
I stripped and rebuilt this morning with lots of Fenwick's Stealth lube on all surfaces, in the hope it will fill in a few gaps (it sets much like a wax) or even just 'damp' the rattling. I don't really care about the sensation of play I just don't like my bike sounding like a bag of spanners if I stand up for descents!
Weirdly neither the Thudglove/loops of innertube/bits of bartape wedged in between linkages seems to do anything to quieten the rattle.
Cane Creek do claim that the new ST has more travel AND harder bushings/pivots as well as being lighter, so maybe I'll save up for one of those for when the current one just gets too sloppy...
Posted : 09/07/2022 12:17 pm
you could be right about the pivots but really they should be much harder so unless the bushes wear through you'd think they'd remain the same diameter . I shall measure them at the next rebuild . I'm like you ..I hate rattles, squeeks etc ..ruins my ride . My brother however couldn't care less and grinds along with all manner of creaks, squeaks and rattles!
Posted : 09/07/2022 3:09 pm
If it's just the rattling that bothers you,hold it in tension with bits of old inner tube (cut in to bands).When the bushes get too worn in mine I will be making my own -->> I have access to a bloke with a lathe 👍😉🙃
Posted : 09/07/2022 9:10 pm
