Servicing RS Pyslos...
[Closed] Servicing RS Pyslos - worth trying doing so by one's self?
Hi All
I have recently purchased a set of RS Pyslos that have got a wee bit of oil showing on stanchions when pumped up.
Assume they need a service.
Is it easy enough to attempt by one's-self or worth getting an LBS to do so? Tight budget means I am not too keen on sending them away to be done.
Assume a new seal kit and oil change is typically what is required?
thank you all very much
Benjamin
Posted : 25/10/2010 11:34 am
I did some coil ones many years ago.
Was easy enough.
Will need a 32mm socket IIRC.
Still have a bottle of oil somewhere if you need some.
Posted : 25/10/2010 12:26 pm
