Servicing an old Fo...
Servicing an old Fox fork
I look after bikes for a friend's children. One of the bikes is an old 26" Orange P7 that has a Fox fork that has started leaking oil from the DS leg.
Its a Fox 32 that is marked 'RL' and 'open bath'. My friend is a single mum anf cant afford to replace/send to the LBS, so what will i need to service it?
Any advice or links greatly appreciated.
Im pretty happy servicing RS forks and seals etc, but just need a guide for these ageing forks so i can get the lad riding again.
Thanks
Ian
Posted : 25/06/2024 4:15 pm
Does it have a serial number which you can enter on this website?ย  https://www.ridefox.com/fox17/help.php?m=bike
That should tell you everything you need to know or at least be a good starting point.
Posted : 25/06/2024 4:21 pm
I cant see a serial number anywhere. Its not obvious like it is on the RS forks
Posted : 25/06/2024 4:30 pm
Ah ok, from that Fox link above it seems like the serial number is under the crown arch. I shall go and have a look.
Posted : 25/06/2024 4:31 pm
Seal kit, oil(s) and grease. Plus the necessary tools.
eBay will be cheaper than the likes of TFTuned.
Posted : 25/06/2024 4:50 pm
Does the open bath make any difference? As its the damper side im assuming its losing damper oil?
Posted : 25/06/2024 8:11 pm
Vanilla or Float?
The vanilla is super easy to service if you can get seals still.ย  I've got a 2007 one that's still going.
The tricky bit is getting the top caps out as they've got quite shallow flats for the spanner/socket.ย  They need care.
Motorbike suspension oil from Halfords in my damper.ย  10wt not 7.5wt in my case as I'm heavier and it was easier to get. 😉
Posted : 25/06/2024 11:02 pm
@garage-dweller its a Float fork. Im guessing it must be over 15yrs old.
There are 3 boys in the house and this one is currwntly with the middle lad. They get used and passed down.
Im hoping i can get seals!
Posted : 26/06/2024 10:50 am
