servicing a Tora 30...
[Closed] servicing a Tora 302 sl fork - help
 Pook
my guide...
doesn't have any info about the removal or the preload adjuster on the left fork. Anywhere that does?
Or can anyone advise? Already I'm stuck at step 1....
Posted : 20/06/2009 1:48 pm
 Pook
anybody?
Posted : 20/06/2009 2:36 pm
 Pook
also, how do you get the fork seals out?
Posted : 20/06/2009 2:37 pm
which seals? wipers?
i use a strong tyre lever if so. Or you could use a large flathead screwdriver wrapped with an old teatowel or something to lever it out.
Apparently heating them up with a hairdryer softens them up and makes it a bit easier
Posted : 20/06/2009 3:12 pm
 Pook
ok great. Thanks. Done now. Now to measure the oil
Posted : 20/06/2009 3:43 pm
 Pook
15wt or 5 in the bottom?
Posted : 20/06/2009 3:50 pm
Don't know if it's mentioned in your instructions, but if your lockout cartridge is in the locked position then it won't go back in. Took me a while to figure out what was wrong, so try not to make the same mistake as me.
Posted : 20/06/2009 5:19 pm
