I'm going to check the usual Parcel Monkey, Parcel2go etc but any couriers that specialise in that distance
£750 value.
I used transglobalexpress a few years back for 6 bikes...
They are a broker who specialise in international stuff, you may need to tweak the box dimensions down a little to get under a specific number. Also you will need to complete customs decs for import to Oz (or the receiver will) make sure it's clean too. Though for £750 it might not be that economic/
Ok will look at them ta.
Did one guestimate with weight and size on parcel monkey was coming back at £360 🙂
I think under 120cms is the magic number.
You get a max size parcel which is 32kg Volumetric weight which is the magic number for air freight and travel, go over and it's normally a lot more, Smaller box or droppig the height works.
Remove the wheels and forks, send wheels separately.
Ensure that nothing, nothing, can move in the box.
It's been a while since I've sent anything to Oz but you should be able to do a bike for less than 150.
Ok food for thought thanks, I need to get to lbs and see what boxes they've got.
Also at that price if you are not posting to yourself there may be import duties/taxes payable
