Recently fitted a sektor 150mm DPC fork and new mavic cross one wheel to my bike and I've just noticed that there's a slight bit of movement between the fork and wheel when tightened.
I've taken the wheel off and the disc side bearing casing has a very slight amount of movement, looks like it's that.
Anyone know the remedy to this?
I have had that a couple of times with a hope pro 2 (15 mm axle sektor) took wheel off and refitted and it's okay???
Nope, tried that a few times. Anyone else for a suggestion?
[s]Replace the bearing if there's play in it![/s]
Sorry, missed the new bit out.
I'd be speaking to whoever you purchased the wheel from. Either the bearings need nipping up a bit or somethings not right. (on my crossrides although they are cartridge bearings, you can adjust the preload on them and remove any play).
