Sektor DPC spring w...
[Closed] Sektor DPC spring weight range & how to drop travel?
Looking at getting some Dual Pos coil Sektors. Can anyone help me out with these questions?
1 what's the standard spring like for an 83kg jeycore bloater such as myself? The official weight range is 160-180lbs, but their air figures are notoriously over sprung. Same for these?
2 If I want to drop to 140 mm travel from 150, is it just a matter of fitting a shorter spring, e.g. [url= http://www.amazon.co.uk/dp/B006KV7678 ]linky[/url] ?
3 Anyone know how much it is to fit the DualFlow rebound damper & where I can obtain the bits?
ta 🙂
Posted : 12/06/2013 7:32 am
 akak
I think you will want a softer spring. I have a fork for sale with the stock spring (I am 93kg) - email in profile if you are interested.
Andrew
Posted : 12/06/2013 7:53 am
 LoCo
Medium spring should be ok for you and drop me amail re. rebound damper
Posted : 12/06/2013 7:56 am
on one are doing air sektors for £230 15mm,(BNIB not grey import) I also think they had coil ones
Posted : 12/06/2013 8:07 am
falkirk-mark - Member
sssshhh! 😆
Thanks all.
Loco, will email later. Ta!
And anybody know the score on q2 re dropping the travel?
Posted : 12/06/2013 8:18 am
I think they come with the spacers and sram online will have the instructions.
I think that's air only? (unless I'm misunderstanding their docs)
Posted : 12/06/2013 9:29 am
 LoCo
140mm dp coils are available, so it's just a spring swap
Posted : 12/06/2013 9:30 am
