Seized bottom brack...
[Closed] Seized bottom bracket - any advice on removing?
I'm worried. I've got a 2002 S-Works M5 hardtail frame and the ancient XT cartridge bottom bracket is well and truly seized in it. I've tried using the correct tools and as much force as I dare, and I'm worried that something else might give before it does.
Has anyone tried pouring a kettle of boiling water on a BB shell to cause a bit of expansion? I can't imagine this doing any harm, but thought I'd just check.
I've already tipped a load of teflon lube down the seat tube to try and get to the bearings from the inside. Still it won't shift.
Anyone got any thoughts? I can't afford to sacrifice this frame!
Posted : 08/03/2010 2:57 pm
you are undoing it the correct way - the drive side thread is reversed?
Posted : 08/03/2010 2:59 pm
http://loctitefreezeandrelease.com/
Posted : 08/03/2010 3:02 pm
Alu on alu yes?
I've heard acid (coke, vinegar) can dissolve teh oxide that alu usually forms.
Posted : 08/03/2010 3:03 pm
tool in bench vice, frame on top?
Posted : 08/03/2010 3:14 pm
Hot water will do no harm and might expand it enough to help - or real heat from a hot air gun but that will knacker the paint.
extractor tool bolted up into place, tool in vice and turn frame.
Posted : 08/03/2010 3:15 pm
also - use a crank bolt and a washer to hold the tool on and then as above in a vice and use the frame to swing on.
Posted : 08/03/2010 3:16 pm
+1 for vice and bolt up the BB removal tool onto the ?octalink axle ๐Ÿ™‚ then spin the frame as you'll get loads of torque ๐Ÿ™‚
Posted : 08/03/2010 3:19 pm
http://www.sjscycles.co.uk/product-Wurth-Wurth-Rost-Off-Ice-400ml--0893240-19954.htm
Ambersil Rust Flash
CRC Freeze-off
Posted : 08/03/2010 3:30 pm
Hot water (cold morning?) plus gaz, diesel even. Give the BB a few shape smacks with a hammer (put one side on the floor -hit the other so the frame is unloaded)
bench -vice - work it back wards and forwards.
It will ive in the end.
Posted : 08/03/2010 3:36 pm
3ft of scaffolding pole over the handle of the ratchet usually does it for me!!!
You can't beat leverage! ๐Ÿ˜€
Posted : 08/03/2010 3:46 pm
