[Closed] Seek parts advise with 29er SS project
Hi there,
- excuse my German but there might be some errors below -
I am currently completing an [u]Inbred 29er single speed[/u] and would be very [u]grateful for any advise regarding [b]final component selection[/b][/u]. Main questions: brakes, tyres, cranks
Here's the list of parts and further down the brief of what I expect from the bike. Any comments and recommendations welcome!
[u]THESE ARE THE PARTS I HAVE ALREADY[/u]
Frame: On One Inbred 29er 16" SwapOut
Fork: On One Carbon
Headset: On One Smoothie Light
Seat: SQ Lab 611
Seat Post: Thomson Elite
Seat Clamp: On-One Forged Alloy
[u]THESE ARE THE PARTS THAT I AM CURRENTLY CONSIDERING[/u]
Stem: Thomson Elite, 50-70mm, 0° or negative°, 25.4
Handlebar: Salsa Alloy Moto Ace 25.4 (-> light, stiff vs. adding compliancy?!)
Grips: Odi Attack
Disc Brakes: Shimano XT M785 (-> should be light, hassle free, mud resistant, maintenance friendly)
Wheelset: HOPE HOOPS PRO3 SP-XC3 with Stans Crest (-> should be light but robust and relatively stiff)
Tyres F&R (?!): Schwalbe Racing Ralph (-> should be light and allow for controlled drift-ability, smooth transition into corners, mud not important)
Cranks: Rotor Agilis (-> should be light, stiff, simplistic)
Chain rings: Rotor, round
Bottom Bracket: Rotor
Chain: KMC X9-SL Superlight Chain
[b]The bike is meant to be:[/b]
- round steering and sweet handling on flowy and tight single-track for fun-biased XC use with the odd bunny hop
- smooth transition from straight to cornering on hardpack and looser forest tracks (that's Norfolk for you)
- predictable driftability and controlled grip, good front-end bite more important then rear wheel traction
- relative compliant ride
- lightweight (<10.5kg) with focus on rotating mass,
- no fuss reliability and hose-down mud-resistancy
- reasonable priced (<1,200,--),
- easy to upgrade to Dingle and gears
The bike shouldn't be/doesn't have to be:
- fancy
- color coded
- heavy on brand names (at least not for the sake of it)
- ultimately stiff
- ultimately grippy
- exceptional in the mud
Many thanks for any comment!
Hendrik
The Racing Ralph's won't go on the Crest 29ers too easily
so if you plan to take them off at regular intervals or suspect you may have to do it on the trail, I'd pick another tyre/rim combo
