Seat post mount rea...
[Closed] Seat post mount rear light on pannier rack
Hi,
I need to mount an exposure flare on my rear pannier rack but the exposure mount is for seat posts. Does anyone know of a solution for this that will ensure the light is mounted securely?
Posted : 12/12/2016 11:00 am
What about the Exposure seat rail bracket?
Posted : 12/12/2016 5:10 pm
The bag would still get in the way of the light if it was mounted on the seat rail. I might have to bodge something!
Posted : 12/12/2016 5:48 pm
The solution is to buy a Cateye that will mount to Saddle rails, seatpost and a rack.
You could also try and adapt a Go Pro Exposure adapter from Raceware, as I believe the Flare is the same diameter as the Joystick. Anywhere you can fix a Go Pro mount will work.
Posted : 12/12/2016 5:54 pm
bit of foam pipe lagging around the horizontal bit of the rack at the rear - attach light to that.
Posted : 12/12/2016 5:55 pm
Sorry, meant attach Exposure seat rail bracket to the back of the rack using a couple of cable ties?
Posted : 12/12/2016 6:05 pm
 OCB
A [url= http://www.madison.co.uk/products/cycling/accessories/pannier-racks-carriers/universal-light-mounting-kit-for-pannier-racks/ ]Madison Universal Light Mounting Kit[/url] is your friend.
The red square section is a bit of tapped alloy that receives the bolts - I don't think it's [i]especially[/i] clear from the product photo, but it's obvious when it's in your hand.
I actually use one on the offside stay of one of my *front* racks to mount a light down below where a bag would otherwise obscure it, but it'd work just as well on the rear (unless you have some unusually perculiar rear rack of course).
Posted : 12/12/2016 7:56 pm
