Seat clamp epiphany
[Closed] Seat clamp epiphany
 spw3
I have finally realised that Hope seatpost quick releases are not very good. I like the idea that they are UK made. I like the look of them and the choice of colours. But they just don't work very well. In order to hold my seatpost in place they have to be tightened up so much it hurts my little hand to use them.
So what else is there out there that looks good and actually works?
Posted : 24/03/2015 8:27 am
Salsa
Posted : 24/03/2015 8:28 am
Salsa +1, although a bit of grease on the Hope can make them more user friendly
Posted : 24/03/2015 8:31 am
Chromag, I got one instead of Hope for my oversized Trek and it has been faultlessly smooth despite any amount of crap thrown at it.
Posted : 24/03/2015 8:32 am
Chromag without a doubt.
Posted : 24/03/2015 8:38 am
 spw3
Cheers for the suggestions guys. My main gripe with the Hope ones is the amount of force I need to exert to get the thing to hold my post in place. Is that what these ones do better? If so, any idea why they work better? What are Hope doing wrong?
Posted : 24/03/2015 8:41 am
everybody salsa !
Posted : 24/03/2015 8:48 am
I've no idea why the Chromag is better than all the others I've had in the past, but it was effortlessly smooth every time?
Most are better than Hope IME. I had one of the almost generic ones (m-part, BBB, Brand-x, something like that) with a plastic bush rather than a brass one and it was smoother and more consistent, needing a lower force, than the Hope. In theory the plastic parts don't last as long as Hope's brass but when they're a fifth of the price it's not really a problem.
Posted : 24/03/2015 8:51 am
Chromag
Posted : 24/03/2015 8:52 am
 spw3
I'm not sure I'm reading you all correctly but I *think* you' might be collectively recommending Salsa or Chromag!
Posted : 24/03/2015 8:54 am
The older on-one with a brass(?) insert works brilliantly.
Posted : 24/03/2015 8:58 am
Don't right off the Hope one just yet. If it's the one with the brass bush then a good clean out and a smear of grease will make it feel much better again.
Posted : 24/03/2015 9:02 am
I have both salsa & chromag - I would prefer that they were both chromag. Not that the salsa ones are bad, they just don't cope with muddiness so well.
spensive, though
Posted : 24/03/2015 10:00 am
Salsa +1
A beautiful bit of engineering. I wouldn't use anything else.
Posted : 24/03/2015 10:12 am
 tomd
+1 for Salsa. Absolutely brilliant. £20 if you look around online.
Posted : 24/03/2015 10:15 am
Salsa. It must take a great deal of engineering know-how to make a seat clamp so hard to close yet offer so little clamping power as the hopes.
Posted : 24/03/2015 10:23 am
people still use QR seat clamps?
Posted : 24/03/2015 10:28 am
Yes, jam bo. Salsa ones! (Or Chromag, apparently, but I wouldn't know about that)
We're a 4 Salsa QR household here.
Posted : 24/03/2015 10:33 am
I found the best answer was to use a bolt up clamp and dropper post.
Do it up once and never worry again. 😀
Posted : 24/03/2015 10:39 am
OP- I have a lovely Chromag qr seatclamp in the classifieds if interested. Black with the brass cam 35mm
Posted : 24/03/2015 10:42 am
I'm with Pinkster!
Posted : 24/03/2015 10:43 am
Just looked up the chromag, it does look good. I'd be getting one of them if I was in the market for one.
Posted : 24/03/2015 10:44 am
I've had Hope, Salsa and Chromag. The Chromag is in a different league to the others. It's not the prettiest clamp unless you like the over engineered industrial look but it works perfectly.
If you needed a non quick release clamp then I'd recommend the Thomson one which requires very little torque on the clamping bolt but really holds the seat post tight.
Posted : 24/03/2015 10:47 am
There's 2 different Chromags btw, the heavier one with the insert is better. That seems to be mostly what's on sale now so maybe the other one is discontinued?
Thing about Salsa and Hope... Salsa is better on day 1. But it's all alu on alu so they very quickly wear ime, and once worn they're worse than Hope. In the long term, Hope is far better imo. Just needs a very occasional clean, and maybe a drop of lube when you're doing other stuff.
Posted : 24/03/2015 11:04 am
 cp
the cheapo CRC brand X and Ragley ones work great - they are simple - a good cam with a nylon bush. But work really really well.
EDIT - I'm with Northwind ref. Salsa. Very good initially, but if you ride in muck and use the qr to drop the post, they quickly become rubbish.
Posted : 24/03/2015 11:12 am
hope one is fine as long as you keep the brass bit clean and lubed.
Posted : 24/03/2015 11:15 am
Sorry, but I had a Salsa. Worked fine when clean, but after a muddy ride when it was full of cak there is no way of fine tuning the bite point unless you got out the hex keys.
Hope all the way. Keep it lubed and never a problem.
Hth
Marko
Posted : 24/03/2015 11:22 am
ha! - I was going to recommend Salsa or Chromag (with the insert).
I've had a Salsa for years without issue, but always like the Chromags whenever I use one.
Posted : 24/03/2015 11:29 am
Salsa here, on three bikes :/
Posted : 24/03/2015 11:48 am
After being advised to try it, I can heartily recommend a drop of wet chain lube in the brass cam in a Hope QR. The effect on how much clamping force is exerted and how easy the lever moves is outstanding.
That said, I'm generally fitting non qr collars as I've gone dropper crazy...
Posted : 24/03/2015 12:00 pm
I like everything about the Hope ones but the fact that my post keeps slipping.
As I've just got Reverb I replaced the QR with a bolt.
No slipping now.
Posted : 24/03/2015 12:07 pm
matt_outandabout - Member
Hope QR's are rubbish, then they break.
Years of slipping post issues (blamed on the frame) cured by switching to the On-One.
Posted : 24/03/2015 12:09 pm
I found the Hope QR fine. Then when I got a dropper I swapped it to bolt up, torqued it to what KS said, and its been fine.
Posted : 24/03/2015 12:13 pm
Ah, it's not just me. I have a fine collection of shiny anodised Hope QR clamps, and yes, I do know about cleaning and greasing.
I find it simpler to use a bolt up now.
Posted : 24/03/2015 1:06 pm
Dropper posts aren't droppy enough for a lot of people so we still use qrs, and I'll just echo what many have said that salsa are way better than hope. Can't believe the poor design be of the hope clamp is still beimg churned out. Least they stopped doing the fingertip killer ball version!
Salsa clamps won't wear out in the lifetime of most frames.
There are lots of "life after Hope" epiphanies awaiting those who decide to stop listening to the fashion chat on forums
Posted : 24/03/2015 1:13 pm
Pff, everyone knows I'm a hope h8er, I slag them at every opportunity but I'm still using 3 Hope QR seatclamps (*). Annoyingly, I sold all my Hopes when I got my Salsas then ended up buying more Hopes to replace those. It's not about Salsa wearing out, it's about them wearing to the point they're sticky and grindy, which on one of mine happened in months.
(* because Chromag are fractionally heavier and I'm a dick about that)
Posted : 24/03/2015 1:50 pm
 jim
I only got a couple of years out of mine before grit took off the anodising, at which point it becomes distinctly less good.
What are you doing to your frames?
Posted : 24/03/2015 1:56 pm
 D0NK
most droppers only go 5" and I need/want 6 and a bit. 5 is fine for most of the time but for silly steep and technical I'll take all the clearance I can get.
Been meaning to drill and chop up some old plastic shock bushes to rejuvenate the cheapo QRs I have (which work nicely but plastic bit fails too soon) but I always end up just cleaning the trusty hope and carrying on with that.
but yeah it is pretty bad design for something bound to get covered in muck.
Posted : 24/03/2015 2:10 pm
I always thought the ball ended Hope design was awful and wouldn't touch it but since they've changed it to a nice flat shape I've bought 2 and had no problem with either. They're nice and easy to operate and clamp adequately enough.
The Salsa one I used to have looked lovely but had no spacer to give a bearing surface and it used to pick up at the interface, got quite stiff and needed cleaning and filing/sanding flat to avoid it.
Posted : 24/03/2015 2:14 pm
reverb is available in 150mm drop.
rase post will give you a full 8" !!!!
Posted : 24/03/2015 2:15 pm
I was quite pleased to discover that my wrong size qr and my right sized allen bolt clamp actually share the same collar design.
I now have a right-sized multi coloured clamp.
Totally irrelevant I know
Posted : 24/03/2015 2:46 pm
 D0NK
last time I looked (when I was buying) only stealths were 6.
rase post
who?
<post google edit>ah right, possibly a little excessive but yeah ok. Not a massive operation, wonder what customer support is like.
Posted : 24/03/2015 4:28 pm
Token shark tail seat clamp is great
No one here will buy it though, nowhere near niche or expensive enough 😉
Posted : 24/03/2015 4:47 pm
