Scott Spark - repla...
[Closed] Scott Spark - replacement bars what is the same but wider?
 DT78
Description of current bars:
Handlebar: Syncros FL1.0 Carbon T-Bar / T shape flat / 9° / 720mm / Syncros Pro lock-on grips
I want something wider - around 740mm it is described as flat but it isn't - my mt zooms are flat and compared side by side there is definitely a small rise. I really like the shape but they are just a bit too narrow
So does anyone know what rise my 'flat' bars are? and what is similar?
Posted : 15/10/2019 1:56 pm
Ergon single bolt on grips could be setup to add 10mm each side (just make sure you plug bar ends).
You can butcher the original grips for the twinloc mounting ring or shim it easily enough (assuming you have one)
Posted : 15/10/2019 3:11 pm
Like most brands, scott/syncros have been going incrementally wider with or bar widths steadily over the years.
The t bar is now 740mm
Here
Posted : 15/10/2019 3:37 pm
 DT78
not cheap are they! may have to look at those grips.
Posted : 15/10/2019 4:18 pm
