Hello
My Scott Genius (M) has started packing down towards the end of a ride and as it is 3.5 years old I guess it needs a service. I would like to know if anyone knows of service providers that come in under a £100? I know TF do not play with these anymore.
Alternatively, I am on the lookout for a second hand one to buy if someone has a cracked frame etc.
Cheers Tupper
Hi
Try Evans cycles in Kendal. They do all the servicing for Scott.
Mine was done in August for £95 + postage of a fiver. About a 2 day turn around. I asked for 10wt oil rather than 5wt and had had an extra shim put in (?, made loads of difference actually had some damping !
contact
Robin
0870 060 5488
fantastic service..
Thanks for the info. I didn't realise you could play with the shims etc,
Brilliant!
