schwalbe tubeless?
[Closed] schwalbe tubeless?
[#1300945]
hey all,
ive got myself a set of dual ply big bettys and was just wondering if they will work tubeless? i know some of the non-tubeless scwalbes can be a bit porous...
Posted : 07/02/2010 12:09 pm
My non UST nobby nics are spot on.
I would assume BB especially dual ply will be no problems at all
Posted : 07/02/2010 12:19 pm
my non UST nobby nics were a nightmare and no matter how much sealant we used they wouldnt seal. and that was using a compressor! I was using 819 rims
they have a different shape around the bead of the tyre that helps them seat on the rim.
Chucky - what rims were you using?
Posted : 07/02/2010 12:26 pm
My nobby nic UST's were fab - bought some non UST racing ralphs and they were a nightmare and the walls leaked so much you'd think they were made of sponge - would pay more for the UST's and the peace of mind.
Posted : 07/02/2010 12:32 pm
355's
Posted : 07/02/2010 12:38 pm
Running non UST Nobby Nic no problem, see lots of others doing the same with ralphs etc. Maybe just got lucky :-)[code]
(355's here too)
Posted : 07/02/2010 12:40 pm
ill give them a bash then...might get lucky lol
Posted : 07/02/2010 12:50 pm
I run a non-UST Fat Albert on the front (ghetto)
and a UST version on the back, as the sidewall is sturdier
Works a treat. No issues with losing air or anything else
Posted : 07/02/2010 1:15 pm
Nobbly Nic and Racy Ralph on Stans Olympic rims here. No problems here at all, but i did use two measures of sealant. I do find the stans sealant works best.
Posted : 07/02/2010 1:56 pm
I've converted Nics, Ralphs, Ron, Freds and Black Sharks, all with a track pump, on Olympics and Rovals, with no problems at all.
There's your problem, the bead of loads of tyres will retreat into the well, UST rims with UST tyres only IMO, too much faff otherwise!
Posted : 07/02/2010 2:29 pm
I'm using Nics and Ralphs non-UST tubelss. No problem sealing etc but they do cut very easily on the sidewalls.
Posted : 07/02/2010 2:59 pm
Non-UST Nics on 819's here. They were no more faff to get on than the Conti Vert. Pro's i'd been using previously. I'd rather put up with 10 mins hassle getting them sealed first time, for the long term weight saving c/w UST specific tyres.
Posted : 07/02/2010 3:04 pm
